99 ej8 with b18c not pulling right
Old Apr 8, 2011 | 09:56 PM
97dc2ftw's Avatar
Default 99 ej8 with b18c not pulling right
Hi I have a 1999 civic ex with a b18c swap it runs good but doesn't not pull right, what can be the problem? it has a p28 ecu b16..
heres some pics:
Old Apr 8, 2011 | 10:11 PM
98civdx's Avatar
Master Detailer
Default Re: 99 ej8 with b18c not pulling right
Start by chipping the ecu and getting an actual dyno tune.
Speedfactory is a great place.
And please be more specific, what do you mean by it doesn't pull right? Does Vtec engauge?
Cel's?
Old Apr 8, 2011 | 10:54 PM
97dc2ftw's Avatar
Vtec engages when the cars warmed up, the car just doesnt pull like my old b18c1 97 dc2 would. Im thinking about trading my p28 for the obd1 p72 ecu would that be better? im located in auburn wa, could I get a speed factory number to ask them on how much for dyno an ecu chip?? and for cel lights, it turns on when I go 80+ mph..
Old Apr 9, 2011 | 02:46 AM
grumblemarc's Avatar
The Grumpiest
Is the P28 chipped? Then get it tuned. If not get it chipped and tuned.
Old Apr 9, 2011 | 10:59 AM
97dc2ftw's Avatar
negative I have a virgin p28, so just get this p28 chipped an car tuned?
Old Apr 9, 2011 | 11:06 AM
98civdx's Avatar
Master Detailer
I am away from my comp right now, just google speedfactory.
Old Apr 9, 2011 | 11:10 AM
97dc2ftw's Avatar
Alright cool, how much is it to get ecu chipped an car tuned??
Old Apr 9, 2011 | 12:25 PM
canadaek's Avatar
if your runing a p28 your intake butterflys also won't be working and that will hurt perfomance also
Old Apr 9, 2011 | 01:41 PM
97dc2ftw's Avatar
Yeah I think that's my issue cause my compression is good, good tranny, changed water pump, changed timing belt, all maintence always done.. I am running a stock p28 with a stock gsr manifold, but I'm getting p72 this Sunday so I will see..
Old Apr 9, 2011 | 03:24 PM
98civdx's Avatar
Master Detailer
No clue what chipping costs, tuning will be in the 300 range.
I totaly forgot about the butterflys.
Have you ever pulled the Cel's to see what they are?
Old Apr 9, 2011 | 07:40 PM
97dc2ftw's Avatar
Nope never pulled CEL lights to check, I'm trading my virgin p28 for a p72, an then have fluid motorsports chip it for $75, they said if I keep my p28, it would be better to get a skunk pro mani, but I'm in college an I'm doing engine work in the summer.. So you guys think a p72 would fix this issue?
Old Apr 9, 2011 | 07:42 PM
97dc2ftw's Avatar
CEL light only turns on when I go 80+ mph, but when I shut the car off an start it again it turns off..
Old Apr 9, 2011 | 08:09 PM
NotAJDMFanBoy's Avatar
You have a couple options for ECUs. You can get the P72, which you'll want to chip if you do any significant modifications.
You could keep the P28 and if you go turbo or high compression, a Skunk2 manifold will make a little more power.
Or you can keep the P28 and get Hondata S300 and it has the option of using different outputs (the wires normally used to actuate the EGR valve, control the AC, etc) to activate nitrous, VTEC, etc. You could use that to control the IABs.
Some ECUs, I think P75s and maybe others, you can ad the components to control the IABs on the board.
When you look at the price of Hondata S300, keep in mind it does realtime updates, drivability is usually better than with Chrome since Chrome is known to have some quirks that take a little more experience to overcome, it has onboard datalogging, boost control, temperature cuts both high and low. Otherwise, look at the Demon RTP. I believe it does about the same stuff as Hondata.
Also chipping can be done pretty cheap. I usually charge people about $25, less if they're friends.
Old Apr 9, 2011 | 08:19 PM
97dc2ftw's Avatar
Yeah I'm getting the p72 ecu, would you be able to do launch control an 2 stage vtec an rev. Limiter on the p72?
Old Apr 9, 2011 | 10:29 PM
98civdx's Avatar
Master Detailer
OR, he could save a ton of money and just use chrome. It will be more than enough unless he's got a all out race car.
Speedfactory uses chrome, and James knows his ****. He is the ONLY person that I would trust to tune my car in WA.
Did you call SF? Kevin/James/Matt should easily be able to point you in the right direction.
Old Apr 9, 2011 | 11:26 PM
97dc2ftw's Avatar
So just get my p72 an have speed factory chip it an all that ****??
Old Apr 10, 2011 | 12:02 AM
98civdx's Avatar
Master Detailer
Honestly I wouldn't even bother buying the P72. I don't know If you can chip the P72..
I would just call speed factory on monday, and ask how much for chip/tune, and do it asap.
2 step/Vtec can be done,I really don't see the point in touching the rev limter.
Old Apr 10, 2011 | 12:18 PM
97dc2ftw's Avatar
I'll get p28 later on when I get the skunk2 manifold..
Old Apr 10, 2011 | 12:19 PM
97dc2ftw's Avatar
So I'm probably getting the p72, just so everything runs good.. For now.,
Old Apr 10, 2011 | 12:52 PM
93egSLEEPER's Avatar
Kevin/James will chip your ecu for $80, at least last time I had it done thats what it was.
Dyno tuning starts at $300, anything special or additional work that need to be done is extra on top of that where labor/parts rates may apply. James will take care of you, great guy and great tuner.
Old Apr 10, 2011 | 02:12 PM
98civdx's Avatar
Master Detailer
You said you already have a P28??
Call speedfactory in the morning and ask them. Matt will likely answer the phone, but he normally can answer all the questions.
Old Apr 10, 2011 | 06:58 PM
97dc2ftw's Avatar
Yeah what I meant was for now I'm gonna get p72 an then in the summer I'll get p28 when I start building..
Old Apr 10, 2011 | 10:16 PM
phoxking's Avatar
or save yourself the money and just chip the p28 to your car's settings now, and rechip it when you do more work like internals or something. but up to you.
Old Apr 11, 2011 | 11:10 PM
97dc2ftw's Avatar
Alright I'll talk to rich at fluid motorsports an will see what's up.. Thx for all he help
Razalie
May 25, 2007 05:06 AM
crashzerothree
Mar 6, 2006 03:17 PM
Zion-I
Feb 12, 2006 09:32 PM
eg6hatch
Aug 7, 2003 04:29 PM
