HELP.........Integra Type-R Turbo Water Temp to hot
Old Apr 8, 2011 | 07:17 AM
ITR 05082's Avatar
Default HELP.........Integra Type-R Turbo Water Temp to hot
Problem with Water is to hot,stock is 190 °F and with Bosst on high RPM is 230 °F.New OEM Water Pump and Mugen Thermostat+Fan Switch installed already but the same problem.I do not know anymore :-(
My set up:
Sleeved Block with Darton Slives
Wiseco Piston 81mm 9:1 Compresion
Eagle Rods
Moroso Oilpan
ARP Headstuds
Stock size Cometic Headgasket
Head is Stock
Stock Manifold
Stock Throttle body
Stock Fuel Pressure
Golden Eagle Fuel Rail
2.9 Drive Shaft
NGK Spark 8 size
10.2mm Spark Wires
Aftermarket Oil Cooler
Omni 4 Bar Map Sensor
Mugen Fan switch
Mugen Thermostat
Mishimotto Radiator with Mishimotto Fan
Autobahn 88 Radiator Hose
AC
Hasport Engine Mounts
1100 ID Injectors
Walbro 255 lph
Peak Boost Turbo kit with Garett Dual BB GT3076 AR82
Boost 32 PSI
Precision Wastegate
Tial Blow-Off
3" Downpipe and Catback with Racing Cat
P72 ECU with Hondata S300
Autometer EGT,Oil Temp,Oil Pressure,Boost Gauge
Old Apr 8, 2011 | 09:30 AM
fcluddington's Avatar
Default Re: HELP.........Integra Type-R Turbo Water Temp to hot
try wrapping your exhaust manifold and getting a turbo blanket.
Old Apr 8, 2011 | 12:03 PM
hjdanzi's Avatar
I had to do a tuning in a 5th gen turbo prelude, and had the same problem.... We called spolling performance and said that their manifolds arent supposed to be heat-wrapped... weird.. but thats what they said... maybe the op's manifold follows the same principle....
Mishimoto products only gave me headaches all the time, and thats why i switched to fluedyne... you wont believe how many hot ect's ive solved by just doing that.
Are you sure that the ECT sender to the cluster is reading fine? maybe thats not the temperature in reality... were are you getting the data from? ems? in which case which EMS are you using?
Old Apr 8, 2011 | 02:00 PM
Spunkster's Avatar
You need a better intake/filter for the Turbo inlet. Right now you are sucking hot air right off the radiator. The best setup would be a custom fabricated cold air style tube that has a filter that can suck the coolest air possible form the fender or bumper area.
Old Apr 8, 2011 | 03:31 PM
ITR 05082's Avatar
Yes Temp is to hot to high RPM Cluster and Laptop have the same Temp.You think i must wrapped the Exhaust Manifold??I will tomorrow deinstalled the Thermostat and drive without Thermostat let's see
Old Apr 8, 2011 | 03:34 PM
ITR 05082's Avatar
sorry i have no space for Air Intake :-/
Old Apr 8, 2011 | 06:11 PM
hjdanzi's Avatar
No... i only had bad experiences with heat wrapping.. thats why spooling performance doesnt recommend it... In fact, my buddy had an oil leak which catch on fire all his wrap... it was a disaster... you shouldnt have HIGH TEMP because of not using a heat wrap...
What i DO recommend is putting heat blanket over the turbo.
Good luck
Old Apr 8, 2011 | 09:07 PM
2k.civic.si's Avatar
is your intercooler completely blocking the front of the radiator? can you take a pic of the front of the car?
on a couple of the high hp integra's ive tuned they had huge intercoolers blocking the front of the radiator and we ended up using a hole saw and cutting holes into the front bumper to get enough air to the radiator to keep it from getting hot.
Old Apr 8, 2011 | 10:31 PM
ITR 05082's Avatar
The Intercooler blocking the front complete,i have stock EUDM/USDM Font Bumper
Old Apr 8, 2011 | 10:45 PM
if you can get a slim fan mounted on the front of the radiator to push air and leave the other one to pull air it will help....you may still need to punch holes into the bumper above the intercooler in front of the radiator.
Old Apr 9, 2011 | 10:09 AM
before you start cutting,(i did by the way) go to Team Integra and look at all the fixes for hot engine after adding turbos. I think most who boost have a problem with temps until they find a way to fix it. Most with your set up and a good shroud and a spal fan dont have probs. Some have had to add oil coolers. There are about 10 fixes all vary by cost, time, looks. Personally I wanted to take a can opener to my hood. GL this is the very first time I have ever heard any negative feedback about heat wrap i am still going to wrap up my manifold and turbo.
velisma
Mar 28, 2010 03:43 AM
imnotjdm
Jul 8, 2009 09:35 AM
an2ny888
May 5, 2009 08:48 AM
Jowee
Jun 8, 2005 07:32 PM
Red D Dragon
Jun 15, 2004 05:51 PM
