83mm bore with stock sleeves?
Old Apr 8, 2011 | 07:13 AM
90SiHatchy's Avatar
Default 83mm bore with stock sleeves?
how does everyone feel about an 83mm bore on stock sleeves with a block guard. im only planning on boosting 5-8 pounds max. ive heard its not safe for high boost but what about a little?
or does anyone know of a company that makes 82.5mm pistons for boost? because 83mm just seems like alot for stock sleeves.
Old Apr 8, 2011 | 07:23 AM
kyden's Avatar
Default Re: 83mm bore with stock sleeves?
are we talking about a b series? i wouldn't even boost with 82mm on stock sleeves.
Old Apr 8, 2011 | 08:03 AM
90SiHatchy's Avatar
yes its a b18a1 block
i was going high compression before and blew a ring which scarred the cylinder wall. all i need is 82.5 but cant find anybody who makes pistons that size
Old Apr 8, 2011 | 12:24 PM
guy_from_nerk's Avatar
Doesn't CP offer 82.5mm pistons?
Old Apr 8, 2011 | 03:06 PM
luck4rmkc's Avatar
Still a bad idea to bore over 81.5 IMO on stock sleeves but if you wanna be the guinea pig I would be happy to learn from your mistakes wink wink
Old Apr 8, 2011 | 03:47 PM
2k.civic.si's Avatar
hehe...please take pics after you blow the motor....i like carnage shots.
Old Apr 8, 2011 | 05:07 PM
ryguy2588's Avatar
I wouldn't go over 81.50mm.
Old Apr 8, 2011 | 05:41 PM
redline1219's Avatar
I had a 300hp gsr bored to 83mm stock sleeves, forged pistons and rods and ctr cams... I put over 10k miles on it, sold it, and the guy still drives it that way! Life expectancy of your motor depends heavily on the TUNE and amount of power you're looking to make. Don't expect a 450hp stock sleeve to last nearly as long as 250hp...
Old Apr 8, 2011 | 11:18 PM
rich7777's Avatar
I wouldn't belive that even if you payed me to. At 82mm the bores will go out of round in no time and have a very good chance failing. 81.5mm is the max you should take them to... The less you take off the better.
Old Apr 9, 2011 | 04:35 AM
Turbo-LS's Avatar
even try to find a 81.25 piston if you can. the thicker you leave the sleeves the better off you are. If the wall is scroed that deep then its time for a new block or sleeves
Old Apr 9, 2011 | 05:13 AM
montrealnitro's Avatar
a block guard won't protect the sleeves in between cylinders.and why would you built an engine and boost less...
fusion645
Dec 31, 2009 08:40 PM
black99x
Mar 11, 2007 10:49 AM
aboobybobpleez
Jan 17, 2007 04:03 AM
Beave0101
Jun 13, 2003 03:36 AM
JeremyL
Jan 11, 2003 02:50 PM
