Safe Bore?
Old Jan 17, 2007 | 02:39 AM
aboobybobpleez's Avatar
Default Safe Bore?
I'm wanting to bore a JDM b16a block .040" and use oversized pr4 pistons for boost. I was wanting to know if this is a safe bore on stock sleeves? I'm going to be using a block guard also but if questioning the 82mm sleeve. Thanks
Old Jan 17, 2007 | 04:03 AM
NJIN BUILDR's Avatar
Default Re: Safe Bore? (aboobybobpleez)
I think you will find that pr4's are a max of +.010" (.25mm).The stock pistons will most likely fail before the sleeves will crack.
90SiHatchy
Apr 9, 2011 05:13 AM
EGandDArida
Sep 5, 2009 04:51 PM
redcivic44
Feb 26, 2006 04:33 PM
Chris Benoit
Aug 10, 2003 09:22 PM
MisterB
Jan 15, 2002 11:26 AM
