relay? ecu
Old Apr 6, 2011 | 08:54 AM
SmoothCTR's Avatar
Default relay? ecu
97 civic dx. Problem is that when the car is accelerated it astarts cutting out immediately. had to drive it home veeery slowly while it was cutting out and everything. Battery light comes on, but the belt is tight, new alternator 1 month ago, new battery 1 month ago. And the third asociated problem is when you hook up the obd 2 scanner it doesnt connect. I am thinking a relay or the ecu itself. I found a thread on another site with the same problem but the guy didnt update after he went to the dealer. so i know this has happened before. thanks and any help is appreciated.
Old Apr 6, 2011 | 09:00 AM
Former User's Avatar
Default Re: relay? ecu
Is 7.5A dash fuse 15 blown?
Is 7.5A hood fuse 43 blown?
Old Apr 6, 2011 | 09:13 AM
SmoothCTR's Avatar
i will check when i get out of work tonight. 43 is the data link connector and 15 is alternator fuse correct?
thanks for the quick reply by the way
Old Apr 6, 2011 | 09:16 AM
Correct
Old Apr 6, 2011 | 09:23 AM
SmoothCTR's Avatar
Correct
would either of those cause the car to cut out when accelerating? its almost like a fuel cut. cleaned the IACV before i realized the dlc wasnt working either. coil, wires,cap, rotor, plugs all 3 months old so i dont think its an ignition issue on the cutting out part.
Old Apr 6, 2011 | 09:26 AM
A blown fuse 15 might cause the problem. When the DLC issue is resolved, check for codes.
Old Apr 6, 2011 | 09:33 AM
SmoothCTR's Avatar
Much appreciated, I will check tonight and let you know tomorrow.
Old Apr 7, 2011 | 09:03 AM
SmoothCTR's Avatar
So last night I leave work. I pulled fuse 15 under dash and it was good. So then I pulled 43 and it was also good. Bummed that the problem wasn't just a simple fuse, just put them back in and next thing I know I turn on the car and there's no cel, no battery light, and it revs smooth as butter. Should I expect this problem to come back.
Old Apr 7, 2011 | 09:08 AM
Sounds like the fuses were loose or making poor contact. Does the scanner now connect too?
Old Apr 7, 2011 | 10:35 AM
SmoothCTR's Avatar
Haven't checked yet but I assume it does. There's no cel anymore, and the car had o2 code before this happened. The o2 was swaped for a new one and same code stayed. I know the o2 is a part of that 15 fuse. So it all connected I guess
nolimitlowrider
Mar 16, 2019 06:49 PM
mugen94
Nov 9, 2014 03:56 PM
Yoitshector
45
Aug 25, 2012 08:27 AM
d0wnShiFt
Jan 6, 2011 03:00 PM
DVPDC2
Jul 29, 2008 02:34 PM
