alternator fuse problem
Old 11-09-2014, 03:32 PM
mugen94's Avatar
Default alternator fuse problem
hey guys, I run a H22a in a civic EK. I installed a new alternator a couple weeks ago, since then no problem. but yesterday my speedometer stop working, and I know alternator and speed sensor is on the same 7.5 fuse. it was blown.. I replace it and instantly it blow again.
replace it again and unplug the connector at the alternator and start the engine. the fuse did not blown. but as soon as I replug the alternator connector, it blown right away.
did some one ever had the same issue ?
Old 11-09-2014, 03:34 PM
Former User's Avatar
Default Re: alternator fuse problem
There may be a short inside the alternator.
If you disconnect the large alternator wire but leave the 4P connector plugged in, does the fuse still blow?
Old 11-09-2014, 03:56 PM
jonsey1886's Avatar
Check the Fuse 15 TSB link in RonJ's sig-it may be applicable to you.
nolimitlowrider
03-16-2019 06:49 PM
mugen94
11-12-2014 04:58 PM
DVPDC2
07-29-2008 02:34 PM
Quick Reply: alternator fuse problem
