Suspension & Brakes Theory, alignment, spring rates....
rear lower control arm HELP!!!!!
Old Apr 2, 2011 | 04:49 PM
deadxxxsoul's Avatar
Default rear lower control arm HELP!!!!!
my rear aftermarket LCA's bushings on my 93 EG hatch are done/shot ...need new ones 3 on each side...does any1 know where can i get replacement or do the stock bushing work if i press then in....need help ASAP ....
Old Apr 2, 2011 | 05:15 PM
civexspeedy's Avatar
Default Re: rear lower control arm HELP!!!!!
Energy Suspension offers pretty good bushings for cheap that you can use in stock arms. Infact, they aren't all that difficult to install on your own(getting the old bushings out is a bit of a pain but doable without a press). For a better performing bushing, Hardrace offers some nice bushings but I'm sure are more pricey and would need to be pressed in. I believe they also sell OE arms with their bushings already installed but again, pricey I'm sure.
Old Apr 2, 2011 | 05:19 PM
will they fit aftermarket LCA???
Old Apr 2, 2011 | 05:56 PM
Oh sorry, didn't see you said you had aftermarket LCAs. What brand do you have? Some don't offer replacements(usually the cheaper, no name kinds). The better known companies might sell replacements. Not all aftermarket LCAs are the same and the don't use the stock bushing dimensions so you're generally left with what they offer.
Loserkidwac
Jul 5, 2006 11:57 AM
Jays91DXhatch
Apr 27, 2005 08:19 PM
CRX_GUY_123
Apr 28, 2004 06:56 PM
RacerBoy
12
Apr 3, 2003 08:06 AM
dynomite55
Jun 11, 2002 06:47 AM
