Best ecu to use
Old Sep 27, 2002 | 03:28 PM
gsr-jr's Avatar
Default Best ecu to use
I am running a 93 civic si with a 98 gsr bone stock. which is the best ecu to use
please give me pros and cons
All OBD I
chipped P28
stock P72
chipped P72
And also what would push more power stock P72 or Chipped P28
Please help me out.
Old Sep 27, 2002 | 04:54 PM
Jared's Avatar
Default Re: Best ecu to use (gsr-jr)
I'd go with the P72 if at all possible.
Old Sep 27, 2002 | 10:25 PM
TimoneX's Avatar
New User
The P72 will maintain compatibility with the 2 stage GSR manifold and the knock sensor. This is certainly the best price is no object solution. Availibility can be a problem.
With the P28 you'll lose both the knock sensor and the ability to control the secondary runners on the GSR manifold. If you're planning to swap to a Skunk2, ITR, or JG manifold in the future that's not a problem. As to the knock sensor...well that's not much of a loss. The pros here are obviously cost & availability. P28s are much easier to find.
The P30 from the Del Sol will work too...but they're even more difficult to find than the P72.
All of these ECUs can be chipped, provided they're OBDI.
team 15
Jan 11, 2007 05:59 AM
poweredbysol
Feb 28, 2006 11:19 AM
cthan3o3
Aug 10, 2005 10:21 AM
H22SRV
Feb 2, 2005 11:21 AM
shonnys92si
Jan 2, 2003 05:02 AM
