92 civic b16a2
i have a 92 civic cx with a jdm b16a2 iam also going to be spraying it with a 75 shot zex fit and your basic boltons i/h/e while i am doing this build i will be posting on here this will be my first b-series motor here is some pic of the car how it sits now
make sure u do a wet kit
here s something to look forward to.......
http://www.youtube.com/watch?v=7ReCCILG4Yc
i recomand you to put colder spark plugs a walbro fuel pump and get tune because at 75hp it raise compression a lot and cause detonation that melt spark plug if you run lean.I did a lot of testing with dry kits and found that over 50 shot on a 4 cylinder you need a tune to get the full benefit.With a wet kit you can tune your air fuel ratio by changing the fuel jets.the fuel quality is also very important try to put the best pump gaz availeble when using nitrous...so have fun building your car!!!
