92 civic b16a2
Old Mar 31, 2011 | 03:00 AM
Eric724's Avatar
Default 92 civic b16a2
i have a 92 civic cx with a jdm b16a2 iam also going to be spraying it with a 75 shot zex fit and your basic boltons i/h/e while i am doing this build i will be posting on here this will be my first b-series motor here is some pic of the car how it sits now
Old Apr 1, 2011 | 01:44 PM
Eric724's Avatar
Default Re: 92 civic b16a2
i just ordered the b16a motor and shift linkage and motor mounts so far heres some pics
Old Apr 1, 2011 | 02:14 PM
rev-speed's Avatar
make sure u do a wet kit
here s something to look forward to.......
http://www.youtube.com/watch?v=7ReCCILG4Yc
Old Apr 3, 2011 | 09:33 AM
Eric724's Avatar
i just got my zex kit today here it is
Old Apr 3, 2011 | 09:58 AM
montrealnitro's Avatar
is it a wet kit
Old Apr 3, 2011 | 10:02 AM
Eric724's Avatar
no its dry iam only going to run a 75 shot on it for now untill i build the the motor up
Old Apr 3, 2011 | 11:29 AM
i recomand you to put colder spark plugs a walbro fuel pump and get tune because at 75hp it raise compression a lot and cause detonation that melt spark plug if you run lean.I did a lot of testing with dry kits and found that over 50 shot on a 4 cylinder you need a tune to get the full benefit.With a wet kit you can tune your air fuel ratio by changing the fuel jets.the fuel quality is also very important try to put the best pump gaz availeble when using nitrous...so have fun building your car!!!
Old Apr 3, 2011 | 12:06 PM
Eric724's Avatar
thanks for the info
Old Apr 3, 2011 | 03:52 PM
SiRCiviC94's Avatar
keep us updated...similar build here
Jdm94Coupe
77
Jul 17, 2011 03:26 PM
