no power to the radio and cig lighter
Old Mar 29, 2011 | 07:01 PM
karrar55's Avatar
Default no power to the radio and cig lighter
THIS CAR IS KILLING ME!!!! ok so i was working on the windshield wiper motor the other day and i removed the cover on the windshield wiper motor to check why its so damn week on power but while i was checking the motor it was still pluged in...i dont know if that created a short or something! so i put it all together and now their isnt any power going to the radio cigerette lighter and clock. i checked the fuse box under the hood and the radio/lighter fuse was fine but the back up radio fuse was blown so i replaced it but no luck(just got back my clock). i checked the fuse box under the dash and thier isnt any power going to the day time fuse i checked all my fuses with a tester too!
please help!!! i want my radio baack
Old Mar 29, 2011 | 08:10 PM
Luck6's Avatar
Default Re: no power to the radio and cig lighter
I'm having the same problem.
Old Mar 30, 2011 | 05:08 AM
noridetoolow's Avatar
If nothing else for now, run a wire from your under the dash fuse box for ACC power to your radio. If you have your clock back then I believe your MEM wire ( yellow ) on the radio is fine, you just need ACC ( red wire ). Tap into an open slot in the fuse panel, make sure to fuse that wire and just run it to your radio red power wire. Unless someone knows what is screwing up the connection between your wipers and radio?? This is a decent fix for now that you can leave in place as long as you need to.
osbunjosh
50
Jan 29, 2024 05:20 PM
Stover954rr
Audio / Security / Video
Jul 31, 2012 03:09 PM
pinkspider
Oct 23, 2006 02:11 PM
_Cyclone_
Jul 17, 2005 08:06 AM
glock
Feb 1, 2002 09:36 PM
