B18a1 (obd0) to b18b1 (obd2) Turns over but no spark
Like the title states, i swapped my obd0 b18a with a 0bd2 b18b1 im using my b18a1s wiring harness i need help finding out what is cause my motor to not get any spark. Any help is appreciated the quicker the better im getting excited lol
The multi ground on thermostat housing its a metal ring with 4 wires crimped on to it is it bolted to the termostat housing? Also any check engine light? And are you getting 12+ volts at the black/yellow wire on the 2 wire plug at the dizzy??
Also can vacum lines cause this I'm not sure if I have all the lines hooked up could anyone post a pick of vac lines fgor the b18b1
Your using an LS wire harness? Did I read it correctly? If so you should be using the stock harness for the car not the b18a1 stock harness.
i have a question for yall i have a b18a1 in my 91 integra gs and wanted to put a b18b1 non vtech in it with the exhisting tranny intake manifold and exhaust what would i have to do
B18aef
Aug 16, 2016 06:02 PM
ekx4
Mar 8, 2016 08:50 AM
CRX91SE
Sep 18, 2010 03:06 PM
DRKSol
Jul 17, 2006 11:48 AM
what ground would do this?
