Not Getting Spark
Old May 11, 2008 | 04:51 PM
Paul*DC4's Avatar
Default Not Getting Spark
I recently put a b16a2 motor into my 95 LS. this motor is from an obd2 civic si and my car is obd1.. i bought a brand new dizzy, new NGK wires, and an obd1-obd2 adapter from password JDM so it would wire to my harness. everything is connected and I am not getting any spark. before all this, I was going to wire my harness so that i would not need to use a dizzy adapter, then couldn't match all the wires properly so i decided to soder all the wires back together. There is one wire left, brown with a black line on it, that does not seem to have a match on the dizzy plug, but comes out of the harness.. would that have anything to do with my not getting spark? could this wire have been grounded into another wire before i was an idiot and cut into it? I am using the obd1 plug i cut off, every wire matched right back up, but i'm left with this brown/black wire. can someone look at there obd1 integra and tell me if they have a brown wire with a black line, and where it goes to? I heard it doesn't go to anything, but i don't see that the answer why would it be there then... any help would be appreciated, car has been sitting for a month and will not start, just cranks, i know i'm getting fuel, but i tested for spark and there is none..
Old May 11, 2008 | 08:37 PM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
Default Re: Not Getting Spark (Paul*DC4)
What ECU are you trying to run?
Old May 12, 2008 | 05:57 AM
Paul*DC4's Avatar
Default Re: Not Getting Spark (Honda Tool)
an OBD1 P28. (92-95 Civic EX).
Old May 12, 2008 | 06:55 AM
Honda Tool's Avatar
Shouldnt you be running an obd2 ECU?
Old May 12, 2008 | 01:11 PM
be8teensee1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Tool &raquo;</TD></TR><TR><TD CLASS="quote">Shouldnt you be running an obd2 ECU?</TD></TR></TABLE> he stated that he has a jumper harness.......check the coil
Old May 12, 2008 | 06:20 PM
96int3gra's Avatar
Default Re: Not Getting Spark (be8teensee1)
check the coil if not that then your icm.....
Old May 12, 2008 | 07:13 PM
Honda Tool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be8teensee1 &raquo;</TD></TR><TR><TD CLASS="quote"> he stated that he has a jumper harness.......check the coil </TD></TR></TABLE>
Ah he has a distributor harness, I thought he meant ECU harness. My fault.
Old May 13, 2008 | 05:33 AM
Paul*DC4's Avatar
Will the ECU i'm using, OBD1, not run the motor? The motor is OBD2..
No, I do not have a jumper harness for the ECU, I have one for the distributer.
Old May 14, 2008 | 05:35 AM
Paul*DC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul*DC4 &raquo;</TD></TR><TR><TD CLASS="quote">Will the ECU i'm using, OBD1, not run the motor? The motor is OBD2..
No, I do not have a jumper harness for the ECU, I have one for the distributer.</TD></TR></TABLE>
bump..... do i need to buy an obd2 ecu and a jumper harness for it so that it will start my car??
Old May 15, 2008 | 06:44 AM
96int3gra's Avatar
.. i dont get what the problem is.... check your wiring.
Modified by 96int3gra at 7:50 AM 5/15/2008
Old May 21, 2008 | 05:58 AM
Paul*DC4's Avatar
Default Re: (96int3gra)
i've checked the wiring over and over again, everything is wired properly, i put in a new engine wiring harness too, still not getting any spark..
Old May 21, 2008 | 07:54 AM
aemintgsr's Avatar
Default Re: (Paul*DC4)
If you dont see any spark out off any of the wires then its your rotor from the distributor.
Old May 21, 2008 | 09:20 AM
Tizight's Avatar
Put a new coil in.
Old May 21, 2008 | 10:44 PM
bizzlekip's Avatar
Default Re: (Tizight)
Check the groung to the thermostat housing
Old May 22, 2008 | 05:32 AM
Paul*DC4's Avatar
Default Re: (bizzlekip)
I put in a brand new distributer. everything is new.
dar5052
Dec 19, 2011 09:29 AM
blackcrx16
Dec 31, 2006 04:23 AM
hotimportcrx
Feb 6, 2006 11:45 AM
B16Vtec
Aug 20, 2001 05:24 AM
