searched, weird grease coming from valve cover breather
Old Mar 26, 2011 | 03:54 PM
djkobe's Avatar
Default searched, weird grease coming from valve cover breather
my b18a1 has a weird white lithium grease like substance coming from the breather and going into my air intake. when i ran the motor with my finger in front of the line there were slight drops of what appeared to be water coming out. there is no coolant in my oil, my over flow is bone dry and the temp always stays at normal operating temp.
any ideas of what it could be? i can get pics if necessary
i did search and could not find any similar problems
also i do have my throttle cable adjusted so that it holds slightly open because my iacv is bad and wont hold a steady idle at all and will stall if it is at normal specs. i dont know if that has anything to do with this current problem
Old Mar 26, 2011 | 05:40 PM
djkobe's Avatar
Default Re: searched, weird grease coming from valve cover breather
also there is a slight smell of gas coming valve cover right after its ran when you take off the oil cap. could this mean i need new valve seats or a valve job?
the compression ran 210 straight across the board when i checked it last month
dannyly17
Apr 27, 2010 08:47 AM
Sprockets
Jan 3, 2006 07:30 AM
b18Gooch
Feb 7, 2005 09:42 AM
Muckman
Oct 27, 2003 09:42 PM
FOrSfEd
17
Jul 9, 2002 07:53 AM
