knocking when i brake?
Old Mar 25, 2011 | 07:17 PM
Wdpfreak145's Avatar
Default knocking when i brake?
So I've been noticing a lot of suspicious things goin on in my car. One thing I picked up on was a kind of slight grinding noise coming from my front passenger side tire. Also, a variable "wobble" in my steering wheel. It's a jerk back and forth of about an inch. And it slows down with speed. Now theres an audible knock or clunk coming from it when I brake. The first sound we diagnosed as a possible wheel bearing issue. Could the other be symptoms of it as well?
Old Mar 25, 2011 | 11:27 PM
Spyke5544's Avatar
Default Re: knocking when i brake?
May sound dumb but are the bolts on your rims tight enough? I mean I don't think it is something someone would normally check when hearing these sounds but it would make sense. The knocking being the tire swooshing back and forth along the bolts. your steering wheel jerking because of the movement of your tire swooshing. and of couse when you change your speed so would the jerking and the knocking change. Worth checking. If not good luck.
Old Mar 26, 2011 | 04:26 AM
Duly noted. Ill check it out.
Old Mar 26, 2011 | 12:49 PM
93b20z's Avatar
Check your tire for separation and check backing plate for rubbing, caliper bolts make sure everthing is tight
Old Mar 26, 2011 | 01:04 PM
Linked's Avatar
make sure all bolts are tight on the caliper and caliper bracket, your rotor may be warped too
Old Mar 26, 2011 | 01:45 PM
fleabag's Avatar
don't overtorque your rims, you'll get warped rotors..
Old Mar 28, 2011 | 12:50 AM
1992hondacivicvx's Avatar
check ur mounts
Old Mar 28, 2011 | 01:28 AM
k.civic.f4i's Avatar
this was going on before my axle snapped. check your axle boot for wear. axle replacement is pretty simple too.
Old Mar 28, 2011 | 06:35 AM
It's not my Rotors because my braking is even. Now the shaking happens even driving. So I know its not brake components. It's got to be running gear and I'm gonna get new wheel bearings.to try out.
Old Mar 29, 2011 | 05:50 PM
We lifted my car up today. The only play I could find in it was left-to-right play and the loose component looks to be the innermost lower control arm gushing. Sound like a good culprit??
Old Mar 29, 2011 | 06:12 PM
ilu's Avatar
ilu
i would like a follow-up on this. i have a similar problem. i think my struts are just really wore out though.
Old Mar 31, 2011 | 02:16 PM
Well when I got under my car the other day to change the exhaust gasket a friend and I noticed how bald the inner portion of the driver side tire was. I took it and got a new tire put on. The uneven wear was caused by the excessive bend in the rim. Now the steering is butter smooth. Still gonna replace the front lca(s).
Old Mar 31, 2011 | 03:06 PM
NOFX's Avatar
H-T White Ops
I've got a torn boot on my passenger side on my Prelude (hope the driver's is okay, but I can't see that without getting underneath it). I get a very distinct and clear *knock* when I brake sometimes as well.
deezpreme
10
Aug 21, 2014 05:05 PM
worder
11
Sep 23, 2011 05:25 AM
FRKWOO
20
Nov 25, 2009 12:13 PM
shadow_ridge
Jan 25, 2007 06:14 AM
carbonlaced
Jun 27, 2006 10:02 AM
