knocking when i brake?
So I've been noticing a lot of suspicious things goin on in my car. One thing I picked up on was a kind of slight grinding noise coming from my front passenger side tire. Also, a variable "wobble" in my steering wheel. It's a jerk back and forth of about an inch. And it slows down with speed. Now theres an audible knock or clunk coming from it when I brake. The first sound we diagnosed as a possible wheel bearing issue. Could the other be symptoms of it as well?
Re: knocking when i brake?
May sound dumb but are the bolts on your rims tight enough? I mean I don't think it is something someone would normally check when hearing these sounds but it would make sense. The knocking being the tire swooshing back and forth along the bolts. your steering wheel jerking because of the movement of your tire swooshing. and of couse when you change your speed so would the jerking and the knocking change. Worth checking. If not good luck.
It's not my Rotors because my braking is even. Now the shaking happens even driving. So I know its not brake components. It's got to be running gear and I'm gonna get new wheel bearings.to try out.
We lifted my car up today. The only play I could find in it was left-to-right play and the loose component looks to be the innermost lower control arm gushing. Sound like a good culprit??
Well when I got under my car the other day to change the exhaust gasket a friend and I noticed how bald the inner portion of the driver side tire was. I took it and got a new tire put on. The uneven wear was caused by the excessive bend in the rim. Now the steering is butter smooth. Still gonna replace the front lca(s).
H-T White Ops
I've got a torn boot on my passenger side on my Prelude (hope the driver's is okay, but I can't see that without getting underneath it). I get a very distinct and clear *knock* when I brake sometimes as well.
FRKWOO
20
11-25-2009 12:13 PM
shadow_ridge
01-25-2007 06:14 AM
carbonlaced
06-27-2006 10:02 AM
