Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Replacing clutch
Old Mar 25, 2011 | 11:30 AM
albertdominguez's Avatar
Icon6 Replacing clutch
OK... So I have a 2002 Civic with a manual transmission. Would not engage into gear with or without clutch. Mechanic said it needs a clutch. Weird, but OK. Bought a clutch kit and began the job. Removed the hub bolts and LCM bolts. Can't separate the lower control arm ball joint. Tried a pickle fork, trashed the boot, tried a hammer, no good, tried the rachet trick, nothing. Need help. Don't know what to do next.
Please help,
Albert
Old Mar 25, 2011 | 01:21 PM
lazlong's Avatar
Default Re: Replacing clutch
Best ball joint removal ever (no special tools needed): https://honda-tech.com/forums/acura-integra-6/popping-front-lower-balljoints-other-random-observations-887859/
Old Mar 25, 2011 | 01:28 PM
It Wasn't Me's Avatar
Ha! Nice find, lazlong.
Old Mar 25, 2011 | 01:31 PM
lazlong's Avatar
^^ Yeah, wish I had seen it about 20 years ago. lol
Old Mar 28, 2011 | 05:34 AM
I tried it. Not with a Craftsman rachet like i've seen but not working. I've been working on this for a few days now and still looking for a solution. Tried the BAH method and nothing. It's been sitting for 2 days with PB Blast soaking on it and still nothing. May work on it some more today.
Old Mar 28, 2011 | 05:39 AM
toyomatt84's Avatar
Sanji
Have you tried using a torch? It's kind of a "last ditch effort" move, but it could free up the seized components.
Old Mar 28, 2011 | 05:51 AM
Not yet. Gonna go pick up a soldering torch this week if I can't get it done today. (Waiting for payday). I hope it'll get hot enough.
Old Mar 28, 2011 | 05:58 AM
One of these?
Should work just fine. (by that I mean it should get hot enough)
Old Mar 28, 2011 | 06:40 AM
That's exactley was I was thinking. I'll try that and let you guys know. I think that'll do it but know I don't know. never had to go that far before. Thanks for the assist.
Old Apr 5, 2011 | 10:59 AM
Done. And I separated to drivers side also without damaging the boot or the joint. Now I can't get the damn transmission away enough to work on the clutch. Don't know how the hell I'm going to do this. I'll be working on this part for the next couple of days, I think. Oh well. I'll figure this out. If anyone has any ideas, please let me know.
Thanks
Old Apr 5, 2011 | 03:09 PM
From the FAQ's..
Clutch Install: Link
Not sure what happened to the alldata pictures, for some reason they're not appearing. (maybe it's just me?) But it does give you an idea of what you're supposed to do.
If I ever get around to changing my clutch, I'll try to keep it in mind to make a new DIY with actual pictures.
Old Apr 12, 2011 | 12:01 PM
Ok.. So I must have made a retarded move somewhere. I began reassembling the car today. (I don't have much time so I do it little by little) Would have been able to fire it up, but ran into a snag. After connecting the clutch slave cylinder, I pushed the clutch pedal and it didn't come back up. I decided to quit before I called a wrecker to take this POS out of my garage. So, I work tomorrow and get off on Thursday morning. I'll continue then. I would like to find out if I have to take the damn thing apart again, or if it's something I can fix without having to do that crap again.
Old Apr 12, 2011 | 12:21 PM
toyomatt84's Avatar
Sanji
Did you bleed the clutch line? You need to re-fill and bleed the clutch line, if you haven't yet. It's tricky to bleed, but is necessary to get proper pedal response.
Old Apr 12, 2011 | 12:45 PM
I didn't disconnect any of the clutch lines. In an effort to avoid having to bleed it. I may go ahead and try that prior to disassembling the tranny all over again, but I don't think that's it. I think it has something to do with the throwout bearing and the lever it mounts to. We'll see.
wasanissanFL
Transmission & Drivetrain
Jan 16, 2016 06:24 PM
taimysho0
13
Aug 29, 2008 10:53 AM
that one guy
Honda Motorcycles
Jun 28, 2006 11:11 PM
ITR.#1446
Jun 25, 2005 12:38 PM
ITR.#1446
