1989 accord dx heater problem
so its weird. my heater doesnt work when im still and at idle but when i drive the heater gets hot. my water pump is fine and my radiator is fine. i was just wondering what else it could? can someone please help! its so annoying! specially in the cold like right now ):
well the only thing i can think of is that it has to be either your control cable, or the heater control valve. The valve keeps coming open and closed for some reason when its not supposed to because the coolant doesnt run through there to make it warm unless that valve opens and closes.
the last time i flushed it and changed it was about a few months ago. i had to change my water pump so i flushed the radiator and yeah the coolants fine. i thought it was my water pump going again but the coolant levels are fine. they dont look dirty or anything
i did change my water pump and i did have stop leak in the system for a bit. the only thing is i didnt flush out the whole system. i only flushed out the radiator to the water pump. so could that be why my heater is ****ing up? this happened recently maybe a few days ago
^ This. I know you just changed it but please recheack the level and bleed it, heat on max and all of the other normal stuff. Then you might think about backflushing the heater core.....yes I like the 3rd gen's so I had to chime in.
Thank you for your input in helping the OP figure out their issue.
To your comment above. I would suggest that you have the Moderators correct the subsections of this site. If you will take a look, there is not a clear place for the 88 and 89 Honda Accords. Yes most if us know that the 3rd gen's ran from 86-89 but if you are new to them how is one to know.
I'll appoligize for the OP bothering you with their post.
Again, Thank you for your help.
EDIT:
hey! so i found out my problem. it seems like theres a leak in my heater line from my engine and thats why there isnt any heat. i was losing water but not enough to show up on the radiator levels. anyways thank you so much for all ur input.
its time for me to get down dirty and replace that horribly position hose ):
Not sure which one of the hoses has a leak but two suggestions.
If one is leaking the others can't be too far behind. Might as well replace as many of them as you can.
Second, while doing this a low pres back flush of the heater core can't hurt.
Good luck
Good luck
^ very good advise especially on a car with a few(read 20+) years on it. I would also think about repalcing the thermostat with a genuine Honda thermostat also. The low pressure backflush is a good idea also especially knowing the system once had dadblasted stopleak in it. I personally hate that stuff. Agree with the post above, this is a total flow issue and should be dealt with accordingly(punny).
Poorman I agree with you. I can't stand posters like that guy. Nothing to add. A troller that only adds dirt to the water of clarity.
OP - Burp the air from the system. Elevate the nose of the car and bubbles can only go one way.
Take note that HonBeer has never STARTED a thread. He must be so good he doesnt have problems. He is R12 certified after all.
https://honda-tech.com/search.php?searchid=1553915
Every post comes with a smarmy ***** attitude. Also note he spelled you're as "your" and PORPOSE instead of purpose along with his post regarding someones grammar and calling them a kindergartner. its instead of it's...etc Get over yourself.
ppl talk bout my old name
Dec 21, 2005 02:15 PM
