Car Is Off, But Oil Light Comes On - HELP!!
Old Mar 23, 2011 | 05:23 AM
end005's Avatar
Default Car Is Off, But Oil Light Comes On - HELP!!
With the car on, no lights. With the car off, and with the key out, the Oil light comes on in red and stays on.
I checked the oil level and everything is normal. I'm not entirely sure what's going on. Has this happend to anyone; or can anyone shed some light on this particular issue?
Old Mar 23, 2011 | 05:24 AM
300whpej's Avatar
Default Re: Car Is Off, But Oil Light Comes On - HELP!!
bad oil pressure switch
Old Mar 23, 2011 | 05:56 AM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help?
The EOPS supplies the ground for the oil light, 12V+ is supplied by a switched ign. source, [hot in run or start] so even if pressure switch is bad, the oil pressure light should not be on with ign. off.
My guess is a problem with the cluster, maybe a bad ground.
I would also check all fuses, test them properly do not just eyeball them. 94
Old Mar 23, 2011 | 06:35 AM
end005's Avatar
Thanks guys - 98 integra gsr.
Old Mar 23, 2011 | 09:12 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Hey check this out, I had a similar problem years ago, though not exactly the same. Battery light stayed on with engine off, and with engine running the battery light went off but the oil light flashed continuously. Turned out to be a bad alternator. Weird I know but it turns out the alternator and ICM under the dash were the 2 common parts between the oil pressure and battery charging circuits. I went through the entire ICM troubleshooting process listed in the Helms and determined that it was okay, so the alternator was the only thing left.
https://honda-tech.com/forums/acura-integra-6/battery-light-while-car-off-1089042/
https://honda-tech.com/forums/acura-integra-6/thoughts-my-battery-light-oil-pressure-light-problem-1090797/
https://honda-tech.com/forums/acura-integra-6/why-my-oil-light-flashing-1089059/
Old Mar 23, 2011 | 11:08 AM
end005's Avatar
Where is the ICM? (Thanks for the threads also!!)
Old Mar 23, 2011 | 11:48 AM
Community Builder
It's under the dash somewhere around the fuse box.
Old Mar 23, 2011 | 02:50 PM
fcm's Avatar
fcm
Old Fart
Are we talking about the ICU, [integrated control unit] because the ICM, [ignition control module] is in the distributor????
Your ICU is mounted/plugged in to the back of the under dash fuse box. 94
Old Mar 23, 2011 | 05:33 PM
Community Builder
yea ICU
PatrickGSR94
Aug 23, 2016 02:54 AM
slow_low_eddie
Apr 17, 2014 06:01 PM
globy123
Dec 13, 2010 10:30 AM
jdm-ek-si
Apr 18, 2008 02:02 PM
Sohc Driver
Jul 9, 2003 11:38 AM
