Oil Light comes on
Oil Light comes on
Hi,
Everytime i turn my car on..my oil light comes on for a second and turns right off and never comes on while im driving. Is this normal?
Khoi
Khoi
1 Post
Re: Oil Light comes on (Sohc Driver)
Yes, the reason the light comes at all and then goes out once you've started the engine is to tell you, that the "oil pressure check circuit"
is working. It's when the light doesn't come on when you start the car that you have a problem. Or while the engine is running, of course.
Re: Oil Light comes on (4crx4me)
The oil light is on when the car is ignited and running. And then it turns off. I am assuming you guys are thinking the oil light is on before i actually ignite the car. Just wanted to clear this up and make sure everyone understands eachother.
khoi
Modified by Sohc Driver at 9:17 AM 7/9/2003
khoi
Yes, I know what you're talking about. My car does the same. All the lights are on when my ignition is on the on click. After I ignite the car on , the oil light and the abs light stays on for another second or so and then turns off. I think it's perfectly normal.
Nukin
04-29-2018 09:36 PM
