Brights not working?
Old Mar 21, 2011 | 09:23 PM
Cap'N Chronic's Avatar
Default Brights not working?
Decided to make another thread for my headlight problem since I need a solution asap and the Lighting section hardly gets any attention.
Here is the original thread:
https://honda-tech.com/forums/lighting-107/having-strange-problems-headlights-2912996/
Anyone know what this stuff is thats inside my headlight plug? Is it supposed to be there?
Old Mar 21, 2011 | 09:54 PM
Linked's Avatar
Default Re: Brights not working?
its old dielectric compound, if that were the cause, your headlights wouldnt work period
and it most likely wouldnt be both sides
pull your bulbs out and check if the filament is dirty/damage (if you had a multimeter, check for any continuity.
a more likely cause is the combination light switch behind the steering wheel
Old Mar 21, 2011 | 10:02 PM
streetglowjoe's Avatar
combo swithc. grounds, bulbs abnd fuses. check alll those and let us know
jwarren1904
Jun 22, 2013 10:24 AM
kayONE
Mar 24, 2013 10:27 AM
VTECROAR96typeR
Feb 9, 2009 05:35 PM
jammin civic
Mar 25, 2004 05:16 AM
DarkCyde SI
Aug 14, 2003 12:12 AM
