Calling ALL Ignition Experts, Help is Needed!!
Here is he Issue, No spark :-( Swapped my Dizzy with a known GOOD one & No spark across All 4-cylinders on my Boosted EM1 B16. Had issues running AEM series-2 Blowing ICM's Regularly. So aem/honata ecu's with no spark to the plug-wires. All Fuses & Relays are Good.
So the Distributor Obviously isnt getting an Signal/Power. I Do have a Greddy Turbo-Timer installed, piggy-back 3-of my Ignition-Switch Wires. Turbo-timer hasnt worked for a while.
Could i have had a wire touch another wire & now my Ignition-Switch is Cooked?
Feel free to Chime in, in need of sum Assistance!
Did you actually check whether the Blk/Yel wire attached to the coil and ICM has battery voltage with the key in ON(II)? If there's no voltage, start by checking whether dash fuse 9 is blown.
the under-dash fuse is Ok. I have not checked for voltage at the ICM & since a Blew 5-ICM's last year, i know which wire u are talking about. LMAO
If you want help and to avoid guessing what the problem is, pull out your multimeter and use it to test fuse 9 and the Blk/Yel wire for voltage.
Ok, Sorry for the late Reply i havent been able to go to where the car is. Its Got 12.26v to the Black/Yellow wire
believe we may have found the problem. Few years ago while running the Aem ems, we had to Re-pin a coil-driver to a different connector. & if im running Hondata now, it needs to go back to the same connector.
am i wrong or Right?
latino honda
May 24, 2019 11:32 AM
lostsonta
Oct 1, 2006 05:58 PM
lostsonta
Sep 29, 2006 08:56 PM
