Max angle for oil drain w/picture
Old Mar 15, 2011 | 05:38 AM
ExVtec's Avatar
Default Max angle for oil drain w/picture
How far off center can the turbo be clocked for the oil drain to function properly?
It's a -4 in and -10 out.
I didn't take a picture of the drain, but you know it's 180 off from the feed, so this gives you an idea.
Acceptable?
Old Mar 15, 2011 | 06:34 AM
TheShodan's Avatar
Moderator
Default Re: Max angle for oil drain w/picture
Too far off-center. Can't me more than 20* off complete vertical in either direction. Time to get a longer feed line. You're just going to blow smoke out of the exhaust.
Old Mar 15, 2011 | 06:45 AM
ExVtec's Avatar
I just have the feed laying there for the picture. I'm concerned w/the drain. The crossmember is directly underneath it, and is dicking me pretty good with the fitting. I don't have much of a choice.
Hmm.
Old Mar 15, 2011 | 09:30 AM
dpetro1's Avatar
take pics of the return. as The Shodan said, 20* is the max angle. Looks like you are almost at 45*
Old Mar 15, 2011 | 09:36 AM
vtechjunkie's Avatar
Won't that ruin the turbo's seals too?
Old Mar 15, 2011 | 10:11 AM
ExVtec's Avatar
It's to hard to get a pic of it. Thats why I took a pic of the feed bc you know it's 180 off that.
Old Mar 15, 2011 | 10:31 AM
wantboost's Avatar
Who is Mr Robot?
yea, thats way too far of center. 20 is accepted but I always like to see 15 or less.
Old Mar 15, 2011 | 10:35 AM
30psi_gst's Avatar
The fittings are aluminum. So if you have th resources you can cut the fitting and angle it accordingly. My friend had to do that with his sidewinder manifold SRT. The fitting was too long and hit the shifter cables. So he cut it, slide the fitting inside a bit and re welded it. You may not have to do the exact same thing. But to make a long story short. You "can" cut the fitting and reweld it to fit your application better.
Your setup will not work like it is now. So you need to change it. You might as well have the center cartridge horizontal if you leave it at that angle.
Old Mar 15, 2011 | 10:41 AM
wantboost's Avatar
Who is Mr Robot?
the fittings have nothing to do with it. its physically the angle of the center section. At that angle, oil will pool in the CHRA regardless of what size feed/return you run
Old Mar 15, 2011 | 11:21 AM
ExVtec's Avatar
Appreciate the responses, this is what I figured. I was told 20*. I'll see what I can do.
Thanks
Old Mar 15, 2011 | 03:06 PM
Deception8's Avatar
unrelated to your original question, but is your turbo JB?
My PTE 5857 JB smoked a bit using a -4an feed. I ended up using a .062" restrictor on it and the problem went away, some people also use -3an feeds to the same effect. Just a heads up in case you have problems, it doesnt seem to effect all PTE JB's.
Also where are you draining to, girdle or top of pan?
Old Mar 15, 2011 | 08:26 PM
ExVtec's Avatar
BB
-4 feed
-10 drain
Pan
Old Mar 16, 2011 | 12:32 AM
30psi_gst's Avatar
No ****. I was telling him he could fabricate the fitting in a way that allows him to run the center cartridge in more of a vertical position. He said with it vertical it hits the cross member. So by putting it more vertically and cutting and re welding the fitting, that could help. Without seeing it i wouldnt know but It was just an idea.
carlos8
Apr 13, 2012 04:39 PM
Kirk@SyndromeAuto
Apr 28, 2006 06:59 PM
hackish
May 17, 2004 09:45 AM
FOrSfEd
Feb 1, 2004 04:33 PM
RATEDR
Jul 2, 2002 07:18 PM
