99 LS/V, messed up missfiring/other messed problems.
Old Mar 14, 2011 | 05:23 PM
Sanox's Avatar
Default 99 LS/V, messed up missfiring/other messed problems.
I'll keep it brief and to the point.
B18B1 block
B16A2 head
No major modifications.
Yesterday I threw a CEL, code 1 - o2 sensor which made the car bog down/missfire a bit, nothing major, had a problem with an o2 sensor with similar symptoms last year, went away on its own.
Today, driving, rolling in neutral to make a turn and the idle just went bat **** insane, jumped to maybe 2k and then down to 0-500, the sound it made sounded as if only one cylinder was firing.
Tried to do the paperclip trick to read the CEL and light was just flickering and getting dimmer and brighter like a ****.
Car doesn't start, when the fuel pump was priming there was an incredibly strong smell of fuel.
For about a minute with the car off and all there was a hissing sound coming from the intake as if some pressure was escaping.
A bit before that event the car over heated to about 3/4 of the way through the temperature gauge, don't know just how reliable the reading is.
Thinking the head gasket might have went and the engine is flooding so I will pull the plugs tomorow and try to see something through that little hole.
Your thoughts on the matter will be greatly appreciated.
Thanks in advance.
Epodgsus
Oct 22, 2018 04:26 AM
845_dapek
Apr 25, 2007 12:32 PM
snatch
11
Apr 27, 2006 06:21 AM
tuan...
13
Feb 24, 2005 09:06 PM
tuan...
Dec 7, 2004 07:41 PM
