gsr 83mm ring gap???
Maybe im an idiot (doubtfull) but i do alot of engines and they like it tighter than that... im normally around 22 and 20 or even 20 and 18 on some of my own engines and they love it
You will get a million different answers on this topic... some say bottom should be wider some say top should be wider! I personally go with smaller gap on top and then bigger gap on bottom. somewhere along the lines of .022 top and .025 bottom should be fine for a street car making around 600whp if you wanna make more power then open them up a little bit. maybe around .024 and .027
depends on fuel used also....
not only whp but also torque and afr plays a factor....
it's all about heat
i'd rather run it slightly loose then finding out it was too little gap tough
it's all about heat
civtegra_hybrid
Sep 25, 2004 11:17 PM
