Track today
Old Mar 13, 2011 | 01:50 PM
350znal's Avatar
Default Track today
My first visit with intake/exhaust(2.5 with a restrictive resonator) was a 15.0@97
My second visit with same mods plus weight reduction and dr's was 14.1@99
Now for todays times..Well with intake, header, exhaust, velocity stack, vafc and a computer( that the vafc is being used to richen it up).
60ft 2.511(having to get in and out of it at the launch)
330ft 6.309
1/8 9.334
mph 81.69
1/4 14.144
mph 104.01
60ft 2.316(held it down and just went spinning)
330ft .....
1/8 9.109
mph 81.70
1/4 13.917
mph 103.98
60ft 2.333( spinning and letting off)
330ft 6.114
1/8 9.135
mph 81.66
1/4 13.950
mph 101.47
60ft 2.255(spinning again and tried to feather it)
330ft 6.023
1/8 9.066
mph 81.43
1/4 13.884
mph 101.67
60ft 2.228( again spinning and trying to get it to hook)
330ft 5.961
1/8 8.981
mph 81.93
1/4 13.773
mph 101.84
I need to drop the pressure in the dr's some more and get the launch down.
Old Mar 13, 2011 | 01:56 PM
boostontheD's Avatar
Default Re: Track today
get some slicks and your ET's will go down so much. and you will never wanna go on radials again.
your 60ft's are terrible you need to get those down.
Old Mar 13, 2011 | 02:26 PM
350znal's Avatar
No know they are.. already look for some fat fives to put some slicks on.
I'm trying to see what I can do on radials. Next visit less air pressure and a burn out to heat them up.
Old Mar 13, 2011 | 03:48 PM
are you heating them up in 1st or 2nd?
best 60ft i did on radials was 2.2 and ran 12.7
best on slicks 60ft is 1.7 and ran 12.1 but fastest et is 11.9
and how well are you heating the tires?
Old Mar 13, 2011 | 03:53 PM
350znal's Avatar
Guess I wasn't heating them up enough. Going to lower the pressure and heat them alot next go around.
Old Mar 13, 2011 | 03:55 PM
heat them in 2nd. tires will heat up much faster and more
Old Mar 13, 2011 | 04:20 PM
350znal's Avatar
Thanks I will try that next time
Old Mar 13, 2011 | 05:03 PM
RaceProfessor's Avatar
2nd or 3rd gear burnout, 12psi in the radials, preload and launch at 6500rpm or so. On my 3rd pass in a car I've never driven before, I did a 1.94 60' on radials which I was happy with because prior to preloading, I couldn't anything better than a 2.0 60'. 13.50 @ 101mph. so the power level is similiar.
Old Mar 13, 2011 | 05:15 PM
350znal's Avatar
Thanks for the advice
Old Mar 14, 2011 | 03:54 AM
LS AzZkIkr's Avatar
I can get consistent 1.9's and 1.8's on BFG's. It's all in heating them up in 2nd gear and some footwork off the line and you will see the ETs' go down. I must say if you feel the car wheel hop, just push the clutch in unless you like buying and swapping transmissions.
Old Mar 14, 2011 | 05:10 AM
350znal's Avatar
If this m2b4 breaks a h2b setup is going back in.
Old Mar 14, 2011 | 07:50 AM
wolve's Avatar
Spinning FTL!
Learn to drive and run low 13's.
Hell, i ran 13.3@103mph in a EJ on 3 year old worn out circuitracing semi's wich where ditched by a local raceteam as worn down
Old Mar 15, 2011 | 12:57 AM
Gold DA9's Avatar
what is your setup to the OP?
Engine/trans, tires, and suspension
my suspension suck on my hatch, and thats something that i currently want to work on. So putting in the clutch is better than letting off the gas and then getting back into it? My best was 13.9 @103 on some 185/60R14 all season tires w/ a 2.3 60' Wheel hopping like no other and geting in and out of the gas...
Old Mar 15, 2011 | 01:07 AM
350znal's Avatar
H22 with bolt ons, m2b4 tranny.... tein springs.. tires are 225/50/15 bfg dr's mounted on some fat fives. The rear sprinted need to be stiffer that is a definate.
Humble Performance
Aug 25, 2011 07:01 PM
B18C1CYA
Jul 26, 2004 08:15 PM
B18C1CYA
Jul 26, 2004 03:26 PM
JDMAflac
Mar 23, 2004 07:29 PM
Adi Radoncic
Sep 1, 2002 11:37 PM
