D-series turbo ring gap???
Old May 12, 2009 | 11:37 AM
jusholeum's Avatar
Default D-series turbo ring gap???
Anyone know where i can get info on ring gaps for my D-series turbo? Im looking for 350+HP any info or help would be great...
Old May 12, 2009 | 11:42 AM
jchrm80's Avatar
Default Re: D-series turbo ring gap???
in the box that your forged pistons came in would probably be my best guess.
Old May 12, 2009 | 12:38 PM
Turbo-LS's Avatar
take your bore in inches and multiply that by .006 for example 81.5mm bored gsr would be converted into 3.2087 inches now multiply that by .006 and the end result is .01922. so that would be your top ring gap and bottom ring gap should be another .002-.003 so that would make the second ring gaps .023 ish
Personally i like a little loose on ring gaps. better to burn a little oil than gall a cylinder wall. What does the specs say for the rings/pistons
Old May 12, 2009 | 02:02 PM
Garage 808 Hatch's Avatar
I RUN .020- .022 TOP AND .021-.023 2ND. but thats me
Old May 12, 2009 | 02:54 PM
jusholeum's Avatar
i just bought the piston ring filer...hopefully i can finish this up by the weekend! so .020 for the first ring and .023 for the 2nd ring!!! ONE MORE NEWBIE QUESTION SORRY GUYS...whats the purpose of the ring gap?
Old May 12, 2009 | 02:55 PM
jusholeum's Avatar
oh thanks for those specific ring gap numbers u guys gave me appreciate all the help i can get...
Old May 12, 2009 | 04:23 PM
Turbo-LS's Avatar
the purpose of ring gaps is al metals expand and contract with temp. if you had to little ring gap for boosted application aka more heat then the ring ends would but up against one another and gall into the cylinder wall and cause all sorts of issues
Old May 12, 2009 | 06:30 PM
jusholeum's Avatar
OOHHH hey thanks Turbo-LS! Its my first D-series turbo build for me! appreciate the help and info looking forward to finishing this build!
Dc4LsTeG
Engine Machining & Assembly
120
Sep 27, 2024 08:56 PM
DulinDragons
Mar 23, 2009 08:41 AM
mahatma
Apr 2, 2006 09:36 AM
crx1856
Sep 16, 2003 05:33 AM
Ri5e
Aug 3, 2002 10:51 PM
