Suspension & Brakes Theory, alignment, spring rates....
gsr brake conversion??
Old Mar 14, 2011 | 09:29 AM
superspadez's Avatar
Default gsr brake conversion??
I'M NEW TO THIS stuff.
i have a 92 vx hatch and i have gsr front and rear brake conversion sitting in my garage
i've done some homework and so far i've ordered gsr booster and master cylinder
and going to order prop valve.
can i just bolt up the abs stuff and not have abs without a problem??
i'm going to need brakes lines from a gsr too right?
anything else?
Old Mar 14, 2011 | 09:31 AM
Default Re: gsr brake conversion??
will a older model prop valve work??? like a 90-93 integra prop valve??
Old Mar 14, 2011 | 05:11 PM
BlueIntegraBoy's Avatar
You need a 4040 proportioning valve. You can remove from either a 90-93 Integra or 94-95 Integra RS. The mounting bracket is different on the 90-93 Integra, but can be swapped out for the stock Civic one, or you can mount the prop valve with one nut (it holds up fine this way).
You will need at least a 15/16" master cylinder. You can get this from a 90-91 Civic EX and it will bolt up straight to your brake booster. You can also get it from a 94-95 Integra RS, but you'll need the brake booster from that car as well as the mounting points are different from the Civic.
You can order brake lines from a 94-01 Integra (any trim) to make it easy. Make sure you take your time and bleed the brakes well.
Old Mar 15, 2011 | 11:46 PM
okay. thanks man! you know if a booster from a gsr will bolt right up? and will it matter if it is abs or not?
Old Mar 15, 2011 | 11:55 PM
Boots's Avatar
why is this in the suspension section? theres a brake section on this forum
Old Mar 16, 2011 | 12:01 AM
whoops....xP
Somalie187
Suspension & Brakes
Jun 27, 2011 09:16 PM
xiongtoua1990
12
Jul 19, 2008 12:37 PM
hazard_one
Dec 11, 2005 01:23 AM
EJ2_B16
Aug 20, 2004 02:34 PM
92B20GSR
Sep 21, 2003 09:19 PM
