locating proportioning valve and brake booster.
Old 09-21-2003, 09:06 PM
92B20GSR's Avatar
Default locating proportioning valve and brake booster.
Im making a trip to the junk yard tomorrow and i need a brake booster and proportioning valve from a integra where are they located at on the car or what do they look like.
thx
Old 09-21-2003, 09:11 PM
I to Smooch Pickle
mingchi69's Avatar
Default Re: locating proportioning valve and brake booster. (92B20GSR)
if you are putting it into a 92-95 civic, you need a brake booster and master cylinder from an integra.. (GSR preffered since their MC is 1" as opposed to 15/16" for LS). Not that big of a deal though. the brake booster is mounted to the firewall and the master cylinder mounted onto the brake booster. For the proportioning valve, you need one off a 94 integra RS which should have the number 4040 stamped on the valve.. the valve is located.. right about in the middle of the firewall on the car. and nearly impossible to get to if the engine is still in there..
It's really not a big deal, and I wouldnt worry about the prop valve, but get the brake booster and MC as it will change the feel of yr brakes dramatically, but you do have to bend the lines to accept the integra MC, but not too hard.
BTW.... i'm still having trouble figuring out light bulb problem..
Old 09-21-2003, 09:19 PM
92B20GSR's Avatar
thx mingchi69 props for the quick and detailed reply much appreciated
JBLAZE622
01-08-2009 05:53 AM
TEGPOWER44
09-08-2003 04:19 PM
Quick Reply: locating proportioning valve and brake booster.
