Start up after 1 year
Old Mar 13, 2011 | 07:44 PM
jakfrost84's Avatar
Default Start up after 1 year
Ok long story short I have a h22a swaped eg civic that has been sitting for a year. Mice are living in the car. (hahaha). I did not put any fuel stabilizer in it before I let it sit. Anyway, I'm about to start working on the car again to finish up after leaving. Besides electrical is there anything else you suggest I do before I start it? I'm gonna change the oil in anyway, but anything else?
BTW: Any good remedies to get rid of mice?
Old Mar 13, 2011 | 08:05 PM
Mazdaholic's Avatar
Default Re: Start up after 1 year
change oil and filter, put a teaspoon of oil into each cylinder, crank the engine a couple of times with injectors and disty disconnected, then plug everything back in, prime the fuel pump and start it up.
p.s.: its also not a bad idea to change the spark plugs and drain the stale gas from the tank, and refill it with fresh gas.
Old Mar 13, 2011 | 09:14 PM
jdm_ek_noob's Avatar
I have an ek sitting in the garage that hasn't been started for a year and a half. the only thing missing is the battery.... and my driving permit lol How was the h22a when you drove your eg?
Old Mar 13, 2011 | 09:23 PM
NotAJDMFanBoy's Avatar
The top end is probably dry. Take your valve cover off and pour oil over everything, just make sure you don't overfill it with oil.
There is a drain plug on the gas tank.
Make sure your battery is well charged.
To get rid of the mice, moth ***** work I believe. And get ready to clean. The smell of mouse urine will linger. Make sure to inspect hoses and be ready for electrical issues. My brother had a Yugo that sat and mice chewed on hoses, wires, all kinds of stuff. Nasty.
Old Mar 14, 2011 | 07:17 AM
Vurt's Avatar
First thing you want to do is remove the bad gas and add some fresh gas in there.
Old Mar 14, 2011 | 07:21 AM
Markley02's Avatar
I had my b16 sit for about 9 months. I changed the oil and started it. No engine problems what-so-ever.
Old Mar 15, 2011 | 10:38 AM
jakfrost84's Avatar
Thanks everyone for the help..... (fingers crossed)
Old Mar 15, 2011 | 11:30 AM
98civdx's Avatar
Master Detailer
Just do what Mazdaholic said, crank it a few times to build some oil pressure.
Put some fresh fuel in it,(or drain old crap) your choice.
My car sat for 7 months. Started up just fine, and it still runing great to this day, almost 3 years later.
Old Mar 15, 2011 | 11:39 AM
MonkeyMagic's Avatar
connect jumper cables, put new gas on top of old gas, turn key to 'start'
we're starting a car that sat for a year, not trying to get the space shuttle into orbit.
TurboCivicR93
Oct 22, 2011 07:17 AM
EKris
Mar 4, 2007 08:37 AM
iHOPEyouCHOKE
Jun 2, 2006 11:02 AM
hondaequikppd808
May 17, 2004 06:06 AM
hwnstyle21
Oct 16, 2002 09:32 PM
