starting problem
Old May 15, 2004 | 12:01 PM
hondaequikppd808's Avatar
Default starting problem
i have a 91 integra, its been sitting in my drive way for bout 2 yrs. the problem is it wont start now, i didnt properly storage it, i didnt start it for 2 yrs, any ideas of what the problem is? what should i do?
Old May 15, 2004 | 12:12 PM
Sack Master's Avatar
Default Re: starting problem (hondaequikppd808)
Gas is probably so varnished it won't spark. Drain the tank is there is a lot of gas in it, change the spark plugs. You'll probably have to change the fuel filter and some other stuff as well. Make sure you are getting spark and fuel. Could be other things. But thats my first guess.
Old May 15, 2004 | 01:29 PM
YelloEco's Avatar
Default Re: starting problem (Sack Master)
exactly what sack master said drain the tank get some good gas in there, then check the plugs, wires,ignition module and of course the battery, cant get no spark if your battery is junk
Old May 16, 2004 | 07:55 AM
Rod.'s Avatar
Default Re: starting problem (MobBoss)
is there any corrosion on the battery?
Old May 16, 2004 | 11:39 AM
tilt's Avatar
i started up a crx that sat outside for 1.5years with its original gas. Though the fuel pump and main relay and water pump all broke while it sat in the sun.
Old May 17, 2004 | 12:31 AM
Default Re: starting problem (tilt)
hey thanx alot all of you!
Old May 17, 2004 | 01:19 AM
Toda Built's Avatar
you might want to drain the old oil and put some new oil in...also crank the engine by hand to lubercate the internals a bit before you try to dry start it
Old May 17, 2004 | 06:06 AM
JimBlake's Avatar
Default Re: starting problem (Toda Built)
And take a quick look at your intake. Check whether mice have made a nest out of your air filter...
rewerbcrx
24
Mar 11, 2006 06:40 AM
aZnInTgRa
Sep 17, 2004 07:20 AM
93egsi
11
Jun 18, 2004 05:37 AM
Solo1
Feb 17, 2004 01:57 PM
crashtest Sonny
42
Nov 21, 2002 10:34 PM
