greddy 18G + Hallman Pro boost controller = crazy spike!
Old Mar 13, 2011 | 03:33 PM
Freshdot's Avatar
Default greddy 18G + Hallman Pro boost controller = crazy spike!
so i went out and purchased a 4 bar map sensor, installed it and moved my boost cut parameter to 13psi on my s300.
Without a boost controller I make 8.4psi, was 10psi on the day of my tune but i have a leak at the BOV.. i don't even know how this is achieved when i believe the 18G is set at 5.5psi from greddy.
anyway..when i hook up the hallman pro, even at its lowest setting the boost wants to go passed 13psi, I don't know how far and i'm not willing to find out..either way why is this happening?
here is how i have it installed:
Old Mar 13, 2011 | 03:57 PM
rev-speed's Avatar
Default Re: greddy 18G + Hallman Pro boost controller = crazy spike!
i had that problem before i had to lower the gate back to 5.5psi to use boost controller
Old Mar 13, 2011 | 04:13 PM
Freshdot's Avatar
My actuator has never been touched which is why I never understood how I made 10psi the day of my tune in the first place, I've never had a boost controller hooked up to this car or touched the actuator rod. There was one time I took the turbo apart to paint the hot side perhaps in that process I spun the rod..anyway dude, how can I turn it back down to 5.5psi? I'm confused as to the process..righty tighty or lefty loosey on that nut on the rod?
Old Mar 13, 2011 | 08:08 PM
Mr.Spec's Avatar
you have it hooked up wrong. bottom port goes to intake manifold. side port goes to wastegate
Old Mar 14, 2011 | 03:48 AM
Freshdot's Avatar
That is how I have I hooked up actually, I just realized that I botched the picture I drew..I have the actuator running to side port on hallman and bottom going to intake manifold.
Old Mar 14, 2011 | 10:35 AM
Freshdot's Avatar
no other suggestions?
Freshdot
Sep 6, 2010 08:06 AM
aberkrombie
Apr 27, 2003 10:25 PM
T3
Apr 23, 2003 10:08 AM
