Got hosed on a block. Need help. Head stud is jammed in block...
Old Mar 12, 2011 | 09:40 PM
5thgencivic's Avatar
Default Got hosed on a block. Need help. Head stud is jammed in block...
First, see this thread http://www.hondamarketplace.com/show....php?t=2909553. My question is if the jammed head stud can stay in if it sits at the right height? Or will it affect the torque? I might have to TIG a piece of steel to the stud and use a long pipe to get it out! That's how hard it is in the block. Either way I have to heli coil the other 2 and weld the hole shut. Thanks for any help as I am quite angry at this transaction...
Old Mar 12, 2011 | 11:11 PM
Default Re: Got hosed on a block. Need help. Head stud is jammed in block...
Got it out with a 3' pipe and breaker bar!!!
Old Mar 12, 2011 | 11:21 PM
B18C1CYA's Avatar
Wow that is sweet bro!! I would use timeserts on the head bolt holes best way to fix them, looks like the hole came from fluid being in the hole and it cracked the out side of the block. txt me tomorrow man
Old Mar 13, 2011 | 12:40 AM
I agree on the timeserts. Heard nothing but good things. I gotta visit you when I come back to NY.
Old Mar 13, 2011 | 09:35 AM
MODS PLEASE MONITOR!!!!!
Old Mar 13, 2011 | 11:50 AM
The guy didn't even use any silicone/sealant on the oil pump when I pulled it!
Old Mar 13, 2011 | 11:57 AM
2k.civic.si's Avatar
you got ripped off...i would trash the whole motor and do it right from the start.
Old Mar 13, 2011 | 03:26 PM
I'm pulling the pistons out now. I'm going to log all specs which should have been done in the first place!!!! I will keep you guys updated.
Get this! I pulled the fitting off the head for the oil feed and there are metal shavings all in the port!
Old Mar 13, 2011 | 04:00 PM
rev-speed's Avatar
hopefully ur luck is better than that last guy that own that block
good luck........
Old Mar 13, 2011 | 07:31 PM
Thanks! I am Irish Getting more leads all the time....
Old Mar 13, 2011 | 09:15 PM
Feel free to chime in anytime snowcamoEG/ Nathan Evans. I know your watching
Old Mar 13, 2011 | 09:25 PM
metal shavings....motor is toast.....block is useless
Old Mar 14, 2011 | 09:33 AM
Block is clean. No metal, no miles since it was at the machine shop. From what I can see anyway lol. No oil in the head either (well a few tiny spots). just straight shavings. Head could be toast or I could get lucky and it's fine... I'll pray for the best lol.
Old Mar 14, 2011 | 11:56 AM
SovXietday's Avatar
I'd be worried about having shavings coming out onto the bearing surface when you rebuild that thing...
sivtechatchy
Jan 13, 2020 11:03 AM
willard steen
Apr 5, 2016 12:22 AM
Rasmusm
Jun 9, 2011 06:02 AM
5thgencivic
Mar 12, 2011 09:38 PM
Fezzie
Jan 5, 2007 07:03 PM
