92 civic hatch wiring problem
Old Mar 11, 2011 | 02:57 PM
JDMb18c1HATCH's Avatar
Icon2 92 civic hatch wiring problem
Ok so I started a wire tuck and am almost done but ran into a small problem. On the driver side under the dash there are 2 plugs a brown one and grey one Wich plug in under the dash and then go threw the firewall to a few female plugs that the engine wiring harness plugs into. The one I breed a pinout diagram of is the grey plug under the dash to the 14 pin plug under the hood by the slave cylinder. I cut the female end off of it to streatch it for the wire tuck and relised after I cut it there were 2 pairbof wires the same color. 2 wires yellow/green stripe 2 wires black/yellow stripe if possible I need a picture that is numbered to as whitch wire goes to each plug. All the rest of the wires are already wired but I don't want to get these switched if they have different purposes and take the chance of burning my car down or having to pull the interior again to switch them. Thanks in advanced
Old Mar 11, 2011 | 05:00 PM
n/a2boost's Avatar
Default Re: 92 civic hatch wiring problem
one yellow/green wire goes to gray plug (looking at it from where the wires go in with the tap you push to unlock it from its female half facing up) bottom row second from the right to the 14 pin plug second row from bottom second one in next to the yellow/red wire....
the other yellow/green wire from the big gray plug goes to the 14 pin plug second row from bottom first spot on the right of the 14 pin plug...
one of the black/yellow wire on the top row of the big gray plug goes to the 14 pin plug second row from the top second one in next to the green/white wire....
the other black/yellow wire on the bottom of the big gray plug goes to the 14 pin plug top left spot....
[IMG] Uploaded with ImageShack.us[/IMG]
Old Mar 11, 2011 | 09:39 PM
thanks bunches took a min for me to figure it out but i did. maybe ill take pictures and post it with number coded lol
uvamosk
Sep 7, 2011 06:06 PM
Tippyman
Apr 11, 2006 11:21 AM
jbell
Apr 23, 2005 02:44 PM
TeamDOHCside
Dec 25, 2003 09:46 PM
FourthGenHatch
Sep 2, 2003 04:20 AM
