Turbo that dont need oil? Comp Turbo.
Old Mar 9, 2011 | 10:37 PM
blinx9900's Avatar
Default Turbo that dont need oil? Comp Turbo.
Anybody seen or tested the new Comp Turbos that dont use oil lines???
All this new turbo tech is getting crazy, first billet wheels, then the BW EFR and now this no oil turbo from comp? Plus it uses a triple ball bearing set up w aluminum bearing housings, wtf!!!
I used the triple bb billet wheel comp turbos and love them, they hit like a hammer, spool quick and hold power to redline no matter what but now no oil lines needed?? This is game changing for manifold design!!
Im dieing to see tests!!!
Old Mar 9, 2011 | 10:39 PM
v8killaz's Avatar
Default Re: Turbo that dont need oil? Comp Turbo.
i know of the airplane turbos that dont have oil lines
they use oil in side in and its sealed. then i think every so hours they change out the oil like A CAR
Old Mar 9, 2011 | 10:48 PM
blinx9900's Avatar
Website says its something like that, a servisable grease pack an ceramic bearings, this is nuts imo!!
Old Mar 10, 2011 | 01:35 AM
rich7777's Avatar
Some crazy **** for sure... i wonder what the downsides are ?
O yeah Blinx, get your *** back onto ek9.org ! we'r all missing you lol...
Old Mar 11, 2011 | 08:46 PM
blinx9900's Avatar
No other comments???
Old Mar 12, 2011 | 11:18 AM
ScorpionT's Avatar
Its an interesting idea, but I would like to see how the lubrication really holds up under extreme heat. I would also be interested to know the cost of replacing said lubrication. I would also like to know if Comp Turbo would allow their customers to regrease the bearings themselves, or if they require the CHRA to be sent in. If its the latter, it would add to the cost and require down time of the car.
I can see the benefit being without using motor oil, starts and stops wouldnt be a problem. Also driving hard wouldnt require frequent oil changes.
Old Mar 12, 2011 | 01:07 PM
vtechjunkie's Avatar
Nice! This will be interesting to see. I think, if they work in the aviation industry, they should work great with the auto as well.
Old Mar 12, 2011 | 05:23 PM
v8killaz's Avatar
i beileve thAT some rajay turbos for aircrafts use this same system
Old Mar 22, 2011 | 10:46 PM
b20ricepower's Avatar
Word I want more info on these. I know formula1 uses ceramic ball bearings for wheel bearings so they gotta be good. Anyone have experience on a honda?
Old Mar 23, 2011 | 05:28 AM
boostedBLUfg2's Avatar
emailed them and comp turbo just gave me a generic response w/ a link back to the article. thanks for the big FU, comp turbos
jarmand
Jun 26, 2011 06:11 PM
kxrider25
Feb 24, 2011 09:59 AM
sivik2nr
Jan 6, 2004 08:31 PM
Pete_SI
Dec 21, 2003 05:00 PM
BoostedH23a1
Jun 12, 2003 04:46 AM
