94 Civic DX -- 95 Integra GSR swaybars
well guys i have a 94 coupe DX with GSR disk brakes all around.
i also have Front and Rear sway bars and i would like to install them this weekend.
Question;
1- Will the Front GSR sway bar bolt-on to the DX front lower control arms? or do i have to use the integra LCA ?
2- The rear should be no problem right? i have aftermarket Rear LCA
3- this might sound stupid but will i really notice the performance handling after installing them?
I will get the car aligned after i finish dialing in my susp.
Thanks for your help
Question;
I am 99% sure you can't use the LCA's. If you have access to the integra ones use them....
The rear's will be fine. You will need aftermarket endlinks, to use them.
Going from no sway to having them, you feel a difference.
When I put my si sway bars in it was almost night and day
but i'll try to look at it this weekend and see what i can do.
NsX_CrX
Jul 27, 2006 10:56 PM
