possible bad ignition switch?
Old Mar 8, 2011 | 09:34 AM
thecruzs2007@yahoo.com's Avatar
Default possible bad ignition switch?
so ive been trying to trouble shoot the problem ive been having on my 94 cx with a d15b vtec..i/h/e and skunk2 IM. It turns on slow and idles for about 30 seconds or so and just shuts off..the fuel pump primes most of the time.. i think its the ingnition switch because it shuts off as if i turned the key to the off position also it will turn on if i retry to start it everytime..i replaced the dizzy with a known good one,checked the grounds, replaced the spark plugs, and replaced the spark plug wires with oem wires. what do you guys think?
Old Mar 8, 2011 | 09:37 AM
Former User's Avatar
Default Re: possible bad ignition switch?
When the engine stalls, are the cluster warning lights on or off?
Old Mar 8, 2011 | 09:40 AM
theyre off but then they come on..
Old Mar 8, 2011 | 09:41 AM
^When the engine stalls?
well it shuts off...and theres no lights..then like a second later they come on but only the check engine light and battery light.
Old Mar 8, 2011 | 09:44 AM
If no cluster lights are lit immediately when the engine stalls, then check the ignition switch. See diagram in FAQs sticky.
ezcape
Jan 13, 2020 03:18 PM
Harry3
Aug 15, 2014 03:34 PM
Somalie187
Feb 17, 2013 12:47 PM
import810
18
May 22, 2007 06:29 PM
ninety4lscoupe
Mar 21, 2006 02:47 PM
