Ignition Switch HELP!!!
Old 03-07-2007, 05:13 PM
import810's Avatar
Default Ignition Switch HELP!!!
I recently purchased a 1995 civic and the car would die if I did not hold the key. I then bought a switch and replaced it and cut the wires for the alarm to put back in. The car will not start not and none of the lights on the cluster go on. What could be the problem?
Here is what I have checked:
Battery 100% working
Disconnected Alarm
Checked for continuity refering to diagram ALL MATCHED!!!
Checked plugs
I have no idea why this is not working. Please help me out guys.
Old 03-07-2007, 05:48 PM
Projekt_2nr's Avatar
Default Re: Ignition Switch HELP!!! (import810)
replace the old ignition
Old 03-07-2007, 09:24 PM
import810's Avatar
Default Re: Ignition Switch HELP!!! (Projekt_2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Projekt_2nr &raquo;</TD></TR><TR><TD CLASS="quote">replace the old ignition</TD></TR></TABLE>
please explain further.... I bought another switch. The key part is fine, I can turn the white piece with a screwdriver
Old 03-08-2007, 06:37 AM
import810's Avatar
cmon i need answers
Old 03-08-2007, 07:21 AM
mhohenlohe's Avatar
When i install alarms in these i use the wires on the back of the fuse box for the ignition kill.
Look around for spliced wires.
Does it get Spark?
Does it get Fuel? (can you hear the fuel pump when you turn the key to ignition)
Old 03-08-2007, 02:04 PM
import810's Avatar
Default Re: Ignition Switch HELP!!! (mhohenlohe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mhohenlohe &raquo;</TD></TR><TR><TD CLASS="quote">When i install alarms in these i use the wires on the back of the fuse box for the ignition kill.
Does it get Spark?
Does it get Fuel? (can you hear the fuel pump when you turn the key to ignition)</TD></TR></TABLE>
the alarm is disconnected and the wires are put toghether.
There is no power and the car doesnt crank. Nothing Happens. No cluster lights come on. I am sure the battery is fine because I have charged it and my headlights and whatnot work.
Old 03-08-2007, 08:39 PM
import810's Avatar
help me
Old 03-08-2007, 08:58 PM
did you check all the wires? connecting to the ignition? do the tumblers not turn?
Old 03-08-2007, 09:13 PM
import810's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Projekt_2nr &raquo;</TD></TR><TR><TD CLASS="quote">did you check all the wires? connecting to the ignition? do the tumblers not turn?</TD></TR></TABLE>
I took apart the looming on the harness adn ran each wire seperatly to be positive that they were all connected
The tumbles turn fine. I can turn the switch with a screwdriver fine. I also sanded down the contacts on the switch.
Old 03-08-2007, 09:24 PM
what type of switch did you install? are you saying that it's now a push button start?
checkall the relay's?
Old 03-08-2007, 09:28 PM
import810's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Projekt_2nr &raquo;</TD></TR><TR><TD CLASS="quote">what type of switch did you install? are you saying that it's now a push button start?
I installed another stock 95 civic ignition switch. Its not a push button start. Check what relays? there are no relays on the harness
Old 03-08-2007, 09:32 PM
expletive im confuced, does it start and the accessories will not turn on or will it not start period?
Old 03-08-2007, 09:48 PM
import810's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Projekt_2nr &raquo;</TD></TR><TR><TD CLASS="quote">expletive im confuced, does it start and the accessories will not turn on or will it not start period?</TD></TR></TABLE>
Does not Start
Does not crank
Cluster does not light up
The switch is pretty much not functioning even though it has continuity in the right positions. Belive me I am so confused and pissed I have spent like 15 hours trying to get something done
Old 03-09-2007, 02:02 PM
import810's Avatar
I hate electronics and wiring
Old 03-09-2007, 11:08 PM
import810's Avatar
any suggestion? wire diagrams?
Old 03-10-2007, 12:41 PM
import810's Avatar
I got another switch today and hooked it up and NOTHING!!! I have checked all the fuses. What could be causing this a short?
Old 03-11-2007, 11:26 AM
import810's Avatar
alarm relays maybe?
Old 03-13-2007, 05:21 PM
import810's Avatar
o man 10 more hours 0% progress I do not know whats wrong
Old 05-22-2007, 06:29 PM
Paul1985's Avatar
What ended up being the cause???
im having similar problems.
Steve LeClere
Honda CR-V & Element
07-21-2012 12:17 AM
RecklessEJ
09-11-2011 03:06 PM
slikz714
07-23-2007 12:06 PM
slikz714
Audio / Security / Video
07-21-2007 01:24 AM
smooz EK
04-11-2006 06:15 PM
Quick Reply: Ignition Switch HELP!!!
