HELP WITH SLAVE CYLINDER!!
Old Mar 7, 2011 | 09:14 PM
jdmfeing's Avatar
Icon6 HELP WITH SLAVE CYLINDER!!
OK I GOT A 94 CIVIC EG AND MY CLUTCH IS ALL THE WAY DOWN ON THE GROUND WHEN STEP ON . BUT WHEN I STEP ON THE CLUTCH AND I NOTICE THAT THERE FLUID LEAKING SLOWLY BEWEEN THE RUBBER PART .SOMEONE HELP I NEED TO GET THIS CAR ON THE ROAD AND SOME DUMMY SAID HE WILL DO FOR 400 LOL..
Old Mar 7, 2011 | 09:33 PM
gwl's Avatar
gwl
Default Re: HELP WITH SLAVE CYLINDER!!
Pretty simple to replace. I would replace both the master and slave cylinder at the same time. Just unbolt the assembly and replace. The master cylinder will need some slight adjustments for the clutch pedal throw. You will need to bleed the lines to get rid of the air bubbles. Mityvacs are the easiest and cleanest way to bleed lines.
Old Mar 8, 2011 | 07:17 AM
05foresterxt's Avatar
You should still be able to drive the car even though the clutch master cylinder is leaking grease. Mine must been leaking the same for a long time before I replaced it. Like stated above, buy both the master and slave cylinder and just bleed the system.
Old Mar 8, 2011 | 07:45 AM
JRSC_EK's Avatar
Be careful putting the new slave cylinder not to mess up the rubber, did you just put a new one on it? Or is it just old and started leaking?
Ajr
Honda S2000
Sep 21, 2014 11:24 AM
Born2Build
May 22, 2011 06:02 PM
nonvtec92
Jun 22, 2007 05:04 PM
93H22A
Apr 9, 2004 10:46 PM
-BlueGSR-
Dec 21, 2002 07:30 AM
