Any DIY's on modifying clusters?
Old Mar 7, 2011 | 08:40 AM
Flipimp1's Avatar
Default Any DIY's on modifying clusters?
Been looking around, and I'm having trouble finding anyone who has done a write up on modifying a cluster for brighter illumination, specifically on an SI cluster? Here's an example of what I'm referring to.
Old Mar 7, 2011 | 09:07 AM
SpoonfedCivic's Avatar
Default Re: Any DIY's on modifying clusters?
http://www.superbrightleds.com/
Replace the stock bulbs with LED lights and you will get the result you're looking for I'm sure. Because that's how it looks to be in the pictures you just posted.
Old Mar 7, 2011 | 09:09 AM
rick_rabies's Avatar
I'm not Rick!
some people take it out and replace bulbs with LED thingys.
Old Mar 7, 2011 | 09:58 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
I PM`d that guy who sells that awhile back. I believe he swabbed it with some liquid to make it a little more transparent
Old Mar 7, 2011 | 10:11 AM
grumblemarc's Avatar
The Grumpiest
I don't think it's that easy. Otherwise everyone's modified cluster would look like this, and they don't.
Old Mar 7, 2011 | 11:50 AM
Flipimp1's Avatar
Yea, the LED's are great, but the light dispersion of them is not nearly what you get with an incandescent bulb. I have seen a write up on D-series.org, but the outcome was not nearly as good as those in my pictures.
Old Mar 7, 2011 | 03:10 PM
Flipimp1's Avatar
http://www.d-series.org/forums/diy-f...i-cluster.html
You can see clearly that removing the paint wont get you close to what the ones I posted look like.
Old Mar 7, 2011 | 03:40 PM
BlueIntegraBoy's Avatar
There will be paint behind those specific parts of the gauge face where light doesn't shine through (like the Si part). Take a q-tip with some acetone (nail polish remover) to the paint to remove it.
Old Mar 7, 2011 | 05:20 PM
97H22AEK's Avatar
I replaced my 97 civic cluster with a 2003 that has led's and it lights up at least twice as bright. I also found a blue one as I think they look much better than red/orange.
Old Mar 7, 2011 | 07:35 PM
yup thats what it was. he swabbed it with acetone. I actually PM`d him to see if he got some SI clusters he can swab and match my mileage
Old Mar 7, 2011 | 08:02 PM
NotAJDMFanBoy's Avatar
Take a EF cluster's lights and ad them to your cluster. They were illuminated from the front, not rear like a EG/EK, etc.
Old Mar 7, 2011 | 09:08 PM
Flipimp1's Avatar
Where do you swab though? All the shine through points on the tach and speedo?
Old Mar 8, 2011 | 08:28 PM
Flipimp1's Avatar
bump
Old Mar 19, 2011 | 09:42 AM
Flipimp1's Avatar
bump for anyone who knows how to mod clusters.
Old Mar 19, 2011 | 09:45 AM
The Grumpiest
Good luck with that.
Old Mar 20, 2011 | 01:47 AM
MyHondaIsSlow's Avatar
LED replacement bulbs are probably your best bet.
Old Mar 20, 2011 | 02:56 AM
The Grumpiest
There's more to it than just bulbs.
Old Mar 20, 2011 | 06:33 AM
Red_Army's Avatar
LEDs a dremel and 2 hours of free time.
all there is to it. at least for me. it does have one or two dull spots but they are barely noticeable. also IMO because the del sol cluster has so many divisions inside it so the light doesn't go elsewhere. i have seen plenty of dull spots in other dashs though.
or buy the strips wrap them around on the inside then wire them up.
Old Mar 20, 2011 | 01:11 PM
teh_pledge's Avatar
What I did with my Si logo and Redline was take some nail polish remover, put it on a cotton swab and rubbed the back of the gauges, specifically behind the si logo and redline, now they are brighter. I'd assume you can do that with the rest of the numbers as well since it worked for my redline.
Old Mar 20, 2011 | 03:09 PM
The Grumpiest
That was already stated but with Acetone. The OP bumped the thread any way. Don't know what he's looking for. If it's a step-by-step you won't find it OP. Buy a spare cluster and practice on that.
Old Mar 20, 2011 | 03:54 PM
teh_pledge's Avatar
Lol that's as "step-by-step" as it gets, unless he wants pictures as well. It's REALLY simple.
Old Mar 20, 2011 | 06:06 PM
Flipimp1's Avatar
I'm not really asking for pictures, although that would be awesome, I'm just trying to get more opinions by people who have done this. I'm sure there is more than one take on how it should be done. But after reading everything I have a pretty good idea of what I need to do now.
miguey310
50
Jan 23, 2010 07:33 PM
mortificationrock
Mar 5, 2008 12:56 PM
guamie
Lighting
Dec 30, 2007 04:36 PM
Midori Green
Nov 15, 2007 07:47 AM
remove account
Mar 28, 2005 05:18 PM
