huge problem ? no big deal ? please help
Ok just got new clutch installed. Not gonna go into detail of car unless u guys need me to. Ok on a fifth gear pull under full boost my car just like cut all poweroff to the motor. Car was fine after it happened it never shut off. I was probably above 6 grand at three quater throttle hitting full boost and then all at once the car just dropped everything and I slowed down and everything was fine. Its on the s300 its an h22a fully built running 12 psi. 430 hp. Is this just in the Hondata. Is it just the wastegate ir is this a huge problem. Thanks in advanced
