Yes another Vtec problem thread
Old Mar 6, 2011 | 07:50 PM
caspitza's Avatar
Default Yes another Vtec problem thread
I have a 97 hatch with a b18c1 swap. type R ECU. Oil level is good. I've had this car for a month now (WI, pretty cold up here) Sometimes vtec hits... sometimes it doesn't... the car has a SI cluster which the oil temp gauge isn't working right... The pin moves but hardly ( fromjust below the C to right above the C) and i'm not even sure if its moving according to temp change. I don't take it high enough for vtec to hit until its been running a while so the engine should be warm. possible vtec solenoid problem? does the faulty temp gauge show or cause the problem?
Old Mar 6, 2011 | 09:33 PM
BrandonR's Avatar
Default Re: Yes another Vtec problem thread
If your thermostat is stuck open, then it will never reach operating temp, causing no vtec engagment. -Later, BR
Old Mar 7, 2011 | 06:58 PM
caspitza's Avatar
Thanks... that makes sense. I'll let you know how it goes
Old Mar 22, 2011 | 06:38 AM
caspitza's Avatar
replaced the thermostat... everything seemed to be fixed until i realized the engine was warming up beyond the regular temp. So i popped the hood once again removed the thermostat housing and realized the thermostat was a 1/3 turn off so the bleed screw on it wasn't allowing it to work. Turned it, put it all back together and were all good! vtec hits hard once again :-D!
supersonic782g
Jun 25, 2009 01:33 PM
everythingwentblack
16
Mar 3, 2008 08:25 PM
ondahush
Feb 22, 2006 03:07 AM
sweetb16
Oct 26, 2004 05:16 PM
b16aeg
Aug 2, 2002 04:41 AM
