transmission issue? help please
Old Mar 6, 2011 | 05:26 PM
f22vtec1's Avatar
Default transmission issue? help please
my ls transmission makes a loud rattle noise at idle as well as it makes a wierder noise when i drive 2 different noises... but other then that it shifts fine any ideas?
before i got it the guy said he changed the clutch & throwout & pilot bearings but he said it always made this noise since he got it
Old Mar 6, 2011 | 06:19 PM
f22vtec1's Avatar
Default Re: transmission issue? help please
bump someone any advise?
Old Mar 6, 2011 | 07:22 PM
Former User's Avatar
Does the noise go away when the clutch pedal is pushed down?
Old Mar 6, 2011 | 07:39 PM
f22vtec1's Avatar
yes it does... but the noise while driving wont go away till i come to a complete stop
Old Mar 6, 2011 | 07:52 PM
Your problem is likely a bad transmission main bearing, typically the input shaft bearing.
Old Mar 6, 2011 | 08:02 PM
f22vtec1's Avatar
so junk it ? is that something easy to fix or pricey?
Old Mar 6, 2011 | 08:06 PM
There is a DIY in the FAQs sticky. Or you could replace the transmission.
Old Mar 6, 2011 | 08:13 PM
f22vtec1's Avatar
k thank you
Old Mar 7, 2011 | 01:49 PM
f22vtec1's Avatar
curious was looking at rebuild kits can i use a rebuild kit from a ys1 or a gsr tranny to rebuild my ls tranny? would all parts interchange with eachother?
Old Mar 8, 2011 | 12:05 PM
f22vtec1's Avatar
bump
phelpsj2
Jan 4, 2010 02:27 PM
mayfly
12
Aug 4, 2009 04:09 PM
diamondstarsforever
Jun 15, 2009 09:50 AM
Ge-money
Sep 12, 2006 06:23 AM
4gnhatch
Jun 24, 2005 06:53 PM
