91 ef/b18 rpm cut out at 6200, and lots of pinging
Old Mar 6, 2011 | 12:48 PM
dealwithit's Avatar
Default 91 ef/b18 rpm cut out at 6200, and lots of pinging
hey all, so i have a 91 ef with a b18a1 in it. it was running perfectly fine after the swap for a few months before it started having issues. it pings when you hit the throttle if its under 4k, and it completely cuts out at around 6200rpm. it gives a fuel system error code once it warms up, then the check engine light goes away when you shut it off. i have replaced the o2 sensor, fuel filter, fuel pump (walbro 255lph), spark plugs, ecu (had a spare, no change), checked grounds, checked the injectors (all spraying perfectly fine), etc.
does anyone have any idea what could be causing this? it started during a nasty cold -30c winter storm and has been like this ever since. please please help, im drawing a blank here.
any thoughts if it could be a temp sensor? im only getting a fuel system code with a stock ecu, and only an o2 sensor code with a chipped ecu(stock map).
Old Mar 6, 2011 | 06:12 PM
dealwithit's Avatar
Default Re: 91 ef/b18 rpm cut out at 6200, and lots of pinging
lol finally figured it out, after fighting this for so long (months) it ended up being the cam timing :s. the belt was pretty tight, i didn't think it could have possibly slipped with how tight it was. i didn't have any of my covers on the side either, but i used a screwdriver down the spark plug hole to find tdc and it showed the cams advanced 1 tooth. i also noticed that the timing mark on the crank pulley aligns with the timing belt when the engine is at #1 tdc
this explains why it stunk like fuel (like it was running rich) but pinged like it was lean......pumping it all strait out the exhaust lol.
mikeyindigo
13
Nov 27, 2015 10:32 PM
dejay2014
Aug 24, 2014 09:16 PM
JDM_SOHC
Apr 12, 2009 02:38 PM
WTB AUTO EK
Jan 6, 2005 08:55 PM
vtec25
10
Oct 6, 2004 08:28 PM
