cluster problems .... help
Old Mar 5, 2011 | 11:12 PM
Lil Rick's Avatar
Default cluster problems .... help
ok.. here is he deal my buddy has a 94 hach dx ... when he got the car the guy b4 him did a wire tuck his heat hand and gas hand wrk but his tach and speedo doesnt he is using a gsr harness... he has swapped ecus,cluster,and speed sensors i kno they work because they came from my car so wat could b our problem... plz help it is driving me crazy tryn find the answer
Old Mar 6, 2011 | 12:49 AM
virgineg6's Avatar
Default Re: cluster problems .... help
not trying to sound like an a$$ but obviously going to be wiring, start at the vss and trace the wires back all the way to the cluster checking for breaks corrosion and pins in the right location do the same for the tach.
Old Mar 6, 2011 | 04:17 AM
BryanM.'s Avatar
Resident Gearhead
Is it throwing CEL code 17 by any chance?
Easy thing to do that has helped me in the past is to clean the VSS terminals and its connector too, even if they look clean.
If that doesn't work, do you have access to a multimeter or a voltmeter? Check for continuity of the VSS wiring. A cheap Hayne's manual outlines the rest of the VSS check procedure.
Old Mar 6, 2011 | 05:48 AM
Prohondari's Avatar
My tach wasn't working properly in my 98 civic ended up being a bad ground
Old Mar 6, 2011 | 08:06 PM
Lil Rick's Avatar
yea i checked the ground it was a slip on kinda ground and i dont have a multimeter and i hate wiring..lol but i will clan the connectors..thanx for help
Old Mar 7, 2011 | 05:43 PM
97H22AEK's Avatar
Or you could just run a new wire to the tach from the blue wire on your ecu. You have to splice into it and you can't cut it !!! 96-04 civics the speedometer wire from ecu is blue/white, not sure about 94 or gsr swap whatever you have.
Old Mar 7, 2011 | 07:51 PM
nater1107's Avatar
what ground was it?
clgarner
Apr 2, 2008 05:39 PM
kyorishin
May 3, 2007 02:15 PM
SSBPGSR
May 6, 2005 10:19 AM
Vtecnsi00
Jul 19, 2004 07:42 PM
JiVe
19
Jul 22, 2003 01:12 PM
