Coolant in cylinder?
Old Mar 5, 2011 | 11:21 AM
airikkCRX's Avatar
Default Coolant in cylinder?
I have a 98 civic ex it seems to be losing coolant I can't find any leaks. I'm starting to think that it's leaking in one of the cylinders. What are all the things I can do without taking it apart?
Old Mar 5, 2011 | 11:35 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Coolant in cylinder?
Compression test. Leakdown test.
Old Mar 5, 2011 | 03:12 PM
Linked's Avatar
as well as milky oil, white smoke from exhaust
Old Mar 5, 2011 | 03:16 PM
MyHondaIsSlow's Avatar
check your overflow, if it has oil in it, you have issues.
do you smell coolant when you drive? over heating issues??
Old Mar 8, 2011 | 08:42 AM
12Zodiac's Avatar
Don't mean to hijack someone else thread but my 95 Civic EX is losing coolant due to overflowing to the coolant reservoir tank. The tank has oil. What does that mean? I have no overheating issue.
Old Mar 8, 2011 | 08:50 AM
The Grumpiest
If you have oil in the overflow tank you have a blown headgasket.
Old Mar 8, 2011 | 08:58 AM
legendrida's Avatar
check and don't drive!
Old Mar 8, 2011 | 09:50 AM
12Zodiac's Avatar
Why, I have been driving the car for awhile without issues. What other damages could cause by continue driving the car with a blown headgasket?
Old Mar 8, 2011 | 09:54 AM
94EG8's Avatar
Seagull Management
At some point it will probably start overheating, and if you're getting coolant in the oil you'll probably spin a bearing at some point.
Old Mar 10, 2011 | 08:28 AM
12Zodiac's Avatar
What's an avarage price for a headgasket job from an Indy shop? I am in Southern California.
Old Mar 10, 2011 | 08:30 AM
The Grumpiest
Why don't you call around and find out? Get it straight from the horses mouth? Let your fingers do the walking? It won't be cheap I can tell you.
redm3turbo
Mar 26, 2013 03:09 PM
blumpfish
Jun 18, 2006 09:23 PM
Bunta eg6
Nov 13, 2005 02:11 PM
JM Performance
Jul 7, 2004 08:17 PM
hybridb18
Aug 6, 2003 09:00 PM
