99 civic 2 wire iacv plug to 3 wire plug conversion help
Old Mar 4, 2011 | 04:08 AM
v8killaz's Avatar
Default 99 civic 2 wire iacv plug to 3 wire plug conversion help
i am swapping a d16y8 auto in my 5 speed civic
both d16y8 but the auto uses the 3 wire iacv plug which i do not have
i know its possible to switch from the auto 3 wire to a 2 wire pretty easily but is it the same for the opposite
is it possible for me to convert the 2 wire to a 3 wire and add a wire to the ecu side
considering my car is 5 speed
the ecu im using is a hondata s300.
Old Mar 4, 2011 | 04:56 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 99 civic 2 wire iacv plug to 3 wire plug conversion help
Hondata is not an ECU.
http://www.google.com/search?q=2+wir...ient=firefox-a
Old Mar 4, 2011 | 04:59 AM
94EG8's Avatar
Seagull Management
What exactly are you trying to do here? If you're planning to run an automatic Y8 ECU it's gonna throw transmission codes, btw hondata only supports 2 wire IACVs.
Old Mar 4, 2011 | 05:33 AM
v8killaz's Avatar
p28 with hondata s300 installed
what im trying to do is run the auto y8 motor with the 3wire iacv on it. is this not possible say a manual y8 ecu p2p i think
i also dont mind codes its temporary until i build the original motor in it
Old Mar 4, 2011 | 05:45 AM
94EG8's Avatar
Seagull Management
You are running a 5 speed transmission though right? Just get a 5 speed Y8 Im ('96 - '98 ideally, the '99 - '00 have air injection holes you'll need to block off) or drill out the back of the IM and install a 2 wire D-series IACV and use an OBD1 throttlebody.
Old Mar 4, 2011 | 12:08 PM
v8killaz's Avatar
Damn this sucks
Old Mar 4, 2011 | 12:48 PM
v8killaz's Avatar
yes im running the 5speeed trans
is there a way i can run the auto ecu and run the wires straight from the plug to the ecu.
i dont want to go find a intake manifold and swap out it out.
Old Mar 6, 2011 | 02:05 AM
v8killaz's Avatar
ended up drilling holes and using a obdI iacv and blocking the 3wire bullshit honda made
Old Mar 22, 2011 | 03:17 PM
Project Dad's Avatar
hate to bring up old posts but I would have swapped you IM's if I had seen this
Old Apr 18, 2011 | 11:09 PM
v8killaz's Avatar
drilling for a 2pin iacv was easier for me since i had a iacv laying around.
sage0187
Nov 20, 2010 06:44 AM
sabideefoo
Aug 27, 2010 10:31 AM
joker4096
Oct 11, 2006 11:40 PM
B18OnTop
Oct 12, 2004 11:29 PM
mr. carpenter
10
May 6, 2004 09:11 AM
