who has done this?
Old May 4, 2004 | 10:27 AM
mr. carpenter's Avatar
Default who has done this?
who has wired up a vtec solenoid with a zdyne one wire ecu? i need your help. do i wire into the plug or the wire itself? also what's the other plug for?
Old May 4, 2004 | 10:28 AM
manson's Avatar
Default Re: who has done this? (mr. carpenter)
mine was wired with a zydne single wire ECU... i personally did not do the ecu install, but will take a look at it.
Old May 4, 2004 | 07:32 PM
help
Old May 4, 2004 | 10:04 PM
ttt
Old May 5, 2004 | 09:12 AM
you people suck
Old May 5, 2004 | 10:53 PM
SiR Kid's Avatar
New User
If we suck so bad, then what do you do, since you can't even figure out the ONE WIRE CONVERSION.
Dunce.
Email Z-Dyne, you stupid *****.
Old May 5, 2004 | 11:10 PM
Default Re: who has done this? (SiR Kid)
um thanks, i was only kidding.
Old May 5, 2004 | 11:47 PM
SiR Kid's Avatar
New User
I got a manilla folder full of paperwork with my SECU Gold... Where's your paperwork. It explains everything very well.
Old May 6, 2004 | 12:06 AM
c jackson's Avatar
threes
just take the wire that comes out of the vtec solinoid, butt connect/solder/tie it to a longer piece of wire, and take the longer piece of wire, shove it through the hole in your fire wall, find out where it should go in the ecu clip, cut the existing wire, butt connect/solder/tie the longer piece of wire to the shorter/recently cut piece of wire and pat youself on the back for your ingenious attempt at using your imagination.
Old May 6, 2004 | 12:22 AM
Smokinsax's Avatar
The Boot
^^^^HAHAHAHAHAHAHAHA!!!!!!!^^^^
But we need pics?!?!?!
Old May 6, 2004 | 09:11 AM
Default Re: (Smokinsax)
i did not get a manilla envelope. i just got one piece of paper with the pin for the ecu and some vauge instructions. i assumed that it went to that one wire but wanted to be sure. is that other plug there the coolant temp sensor?
williamcollins
Jul 8, 2017 01:24 PM
iamthefollower
Apr 4, 2012 08:32 AM
