inline pumps
Old Sep 26, 2002 | 08:03 AM
turbofed EX's Avatar
Default inline pumps
i need an inline pump, what brand is recomended and where should i get it?
Old Sep 26, 2002 | 08:14 AM
The^Mad_Hacker's Avatar
Default Re: inline pumps (turbofed EX)
I got a Zex one.
Old Sep 26, 2002 | 08:15 AM
b18bturbo's Avatar
Default Re: inline pumps (The^Mad_Hacker)
msd,zex,nos,airtex all are not bad inline pumps each pump is priced differently though.
Old Sep 26, 2002 | 08:38 AM
boostedcivicsir's Avatar
Mr. Badwrench
i have a walbro intank and havent had a prob yet.
Old Sep 26, 2002 | 09:06 AM
Default Re: inline pumps (boostedcivicsir)
i have a holley 255lph intank and fmu, adj. fpr and it seems to run lean at the end of the gears except 1st, 2nd trying to run 9psi
Old Sep 26, 2002 | 10:41 AM
b00stedsi's Avatar
ill trade you fuel pumps, i have a airex. enable IM
Old Sep 26, 2002 | 11:24 AM
Default Re: inline pumps (turkish)
not interested in trading gonna keep and use it with the inline if i can
is there ant specific stores online that sell them
[Modified by turbofed EX, 3:37 PM 9/26/2002]
Old Sep 26, 2002 | 12:30 PM
shadowdawn's Avatar
Default Re: inline pumps (b18bturbo)
What he said ALL will work fine with FMU setup
Old Sep 26, 2002 | 12:49 PM
Default Re: inline pumps (shadowdawn)
so if i get the inline it should work with 9psi?
inline pump, intank pump, fmu, adj. fpr should all work together with a little tuning
or should i just new injectors
[Modified by turbofed EX, 4:52 PM 9/26/2002]
Old Sep 26, 2002 | 01:19 PM
tegpilot's Avatar
running lean at only 9 psi ??
I use the exact same pump as you...no problems....are u using the right plugs?...NGK BKRE 7E is what i use...i dont think u need an additional inline
Old Sep 26, 2002 | 01:27 PM
Default Re: inline pumps (tegpilot)
using bosch platinum4, are those NGK's the 2 step colder at what gap? thanks
Old Sep 26, 2002 | 01:48 PM
highmilehatch's Avatar
You need an inline if your running an fmu. This topic has been beaten to death. High pressure fmu=need high pressure inline. Yes, bigger injectors and standalone would be a better idea.
kpjo4
Jun 4, 2010 05:19 AM
YellowPhoenix095
May 14, 2007 06:30 AM
Unjockable
Dec 24, 2004 11:05 PM
SIK IN DA HED
Nov 13, 2003 08:53 AM
R-1303
Jul 11, 2002 04:15 PM
