EG Hatch Wont Start **
Old Mar 3, 2011 | 06:18 PM
Mrevann's Avatar
GDD Black Reject
Default EG Hatch Wont Start **
So I Installed My new D2 Spec Headlights w/Citylights but Citylights arent installed yet. After the install i tried starting my car and going for a drive to test ..plus my fogs were flickering too .. but it wouldnt start so .. im stuck .. any ideas.....
ive check the battery .. i think it could be the alternator possibly the starter ...
Old Mar 3, 2011 | 06:20 PM
Former User's Avatar
Default Re: EG Hatch Wont Start **
Are you saying the starter doesn't crank the engine when you turn the key to ON(III)?
Did you disconnect the ground wire attached to the top of the transmission?
Old Mar 3, 2011 | 06:22 PM
Mrevann's Avatar
GDD Black Reject
Ron ... Nope.. it doesnt turn over on nothing ... it just clicks.. then my alarm goes off likes its on crack.
Old Mar 3, 2011 | 06:23 PM
Mrevann's Avatar
GDD Black Reject
the only ground i took off was the one .. for my fog lights.
Old Mar 3, 2011 | 06:24 PM
The battery may be low on charge. Take it to an auto parts store for testing and charging. Also clean the battery connectors and the ground wire attached to the chassis in the engine bay.
Old Mar 3, 2011 | 06:26 PM
Where is this ground?
Mrevann's Avatar
GDD Black Reject
ok ill do that .. and i believe it the chassis. its under my splash shield
Old Mar 3, 2011 | 06:28 PM
If that ground runs to the top of your transmission, that could be the problem.
Old Mar 3, 2011 | 06:32 PM
Mrevann's Avatar
GDD Black Reject
i dont think it is .. cause the ground connects to the harness that came with it and then .. goes wild but i will let u know tomorrow Ron .. i really appreciate it sir.
Old Mar 4, 2011 | 08:14 PM
Mrevann's Avatar
GDD Black Reject
it was the battery thanks ron ... u can lock this now
Midnight EG6
Oct 10, 2013 11:57 AM
gooberwolf
Mar 9, 2009 04:11 PM
luv2boost
Oct 25, 2008 06:47 PM
jackarse
Nov 12, 2006 10:14 AM
